Author Topic: copy layer properties ObjectDBX  (Read 1959 times)
Humbertogo
« on: August 28, 2007, 02:44:52 AM »
is there a way to copy layer with  properties from one doc Viewport to another using
ObjectDBX
« Last Edit: August 28, 2007, 02:51:07 AM by Humbertogo »
Bryco
Re: copy layer properties ObjectDBX
« Reply #1 on: August 28, 2007, 09:59:45 AM »
Humbertogo, I'm not sure about your question.
If you want to freeze layers in a viewport you add xdata tp the viewport. So it's possible.
Humbertogo
« Reply #2 on: August 28, 2007, 10:22:00 AM »
in my program i importing a  Layout using ObjectDBX
but i need to know witch layer are freeze in the viewport
(Layout)
Bryco
« Reply #3 on: August 29, 2007, 11:13:53 AM »
This is trickier than I thougth it would be.
I think your are better making the pviewport then add the xdata that trying to copy the pviewport
Sub CopyVpLayerStates(Vp As AcadPViewport, NewVp As AcadPViewport, NewDoc As AcadDocument)
    Dim Doc As AcadDocument
    Dim Xd, Xv
    Vp.GetXData "Acad", Xd, Xv
    NewVp.SetXData Xd, Xv
    NewVp.Update
    NewDoc.MSpace = False
    NewVp.Display (False)
    NewVp.Display (True)
    NewDoc.MSpace = True
End Sub
