Author Topic: Replacing a caracter in a VBA string  (Read 3094 times)
iliekater
« on: August 27, 2007, 02:19:32 PM »
I wonder if it is possible to replace a caracter in a string . For example in the following string :
"d:\Program files\Folder 1\Sub folder 2"i'd like to replace the caracter "\" with "\\" , resulting :
"d:\\Program files\\Folder 1\\Sub folder 2"Is it possible ?
I want to do this in order to convert some paths determined by VBA , to paths that Lisp will understand (it uses \\ instead of \) .
« Last Edit: August 27, 2007, 02:21:29 PM by iliekater »
David Hall
  • Automatic Duh Generator
Re: Replacing a caracter in a VBA string
« Reply #1 on: August 27, 2007, 02:25:25 PM »
yes, use Instr() to find it, add it at the positions found
Guest
« Reply #2 on: August 27, 2007, 02:35:43 PM »
I use REPLACE
Replace(expression, find, replace[, start[, count[, compare]]])
Public Sub Main()
    Dim strNewString As String
    strNewString = Replace("d:\\Program files\\Folder 1\\Sub folder 2", "\\", "\", 1)
    MsgBox strNewString
« Last Edit: August 27, 2007, 02:37:09 PM by Matt W »
« Reply #3 on: August 27, 2007, 02:41:18 PM »
Use replace
Dim Path as String
Dim NewPath As String
Path = "d:\Program files\Folder 1\Sub folder 2"
NewPath = Replace (Path, "\", "\\")
NewPath will equal "d:\\Program files\\Folder 1\\Sub folder 2"
dangit .. Matt beat me to the punch ...
Guest
« Reply #4 on: August 27, 2007, 02:42:01 PM »
Woohoo!!
« Reply #5 on: August 27, 2007, 02:42:45 PM »
Woohoo!!
I need to learn to type faster ...
<edit* and I obviously need to pay closer attention to what I am doing>
« Last Edit: August 27, 2007, 02:55:30 PM by Keith™ »
David Hall
« Reply #6 on: August 27, 2007, 03:01:26 PM »
I knew there was an easier way, I just couldn't remember REPLACE off the top of my head
Maverick®
« Reply #7 on: August 27, 2007, 05:50:29 PM »
Woohoo!!
Naw, He has just been waxing on and waxing off more than you.  :-D
iliekater
« Reply #8 on: August 27, 2007, 06:27:46 PM »
Thanks alot guys . It's going to be helpful . :-)
Dnereb
« Reply #9 on: August 30, 2007, 10:22:33 AM »
What about C:\test\\\Stuff.dwg
Public Function RemoveRepetitiveBackSlashes( StrText, Optional AlternativeString as String) as String
Dim StrFind as String
Dim StrDoulblure as String
if Len (Alternative) > 0 then
    StrFind = AlternativeString
else
    StrFind = "\"
end if
StrDoublure = StrFind & StrFind
Do While( Len(RemoveRepetitiveSlashes ) <> Len(StrText)
    RemoveRepetitiveSlashes = StrText
    StrText = Replace(StrText, "\", "\\")
loop
End Function
