Author Topic: Who Owns the Files?  (Read 5459 times)
vinnyg
Who Owns the Files?
« on: August 22, 2007, 04:21:26 PM »
Hi all,
O.K., so an Architect designs and puts on Acad the drawings. Who owns the Acad
files. The client paid big money to have his project designed. Isn't the client entitled to
a copy of those files at least? What's your thoughts and/or experience with this situation?
vinny
M-dub
Re: Who Owns the Files?
« Reply #1 on: August 22, 2007, 04:25:51 PM »
One word:
Yes!
We've been in the same situation as your client before.
Guest
« Reply #2 on: August 22, 2007, 04:30:09 PM »
I think it would probably depend on the wording in the contract.  Most of the time, our "design" and/or "contract" drawings never make it to the client.  They might end up with some as-builts (compiled by us) with information from the job site.
For example... if Joe Schmoe is doing the electrical ductbanks for a site, we'll typically get a drawing from him that has some spot elevations (top of ductbank) and shots showing the width when it's encased in concrete.  Then we might get some stuff from John Doe about the water line.  We'll then take the info from both parties and mash it all together and make it look "pretty" since they'll most likely be using different standards, if any.
Josh Nieman
« Reply #3 on: August 22, 2007, 04:32:20 PM »
Hi all,
vinny
Depends on the contract.  Our contract states that the deliverables will be sets of paper of whatever size is appropriate to the specific job... usually we specify that we will provide 3 sets of 24x36 and a set of 11x17s... it varies depending on client, but by default we don't supply .dwg files, and hesitate to do so.  There's only one client that demanded the source files for their project, and we were ok with that.
« Reply #4 on: August 22, 2007, 04:33:45 PM »
It is a tough call for some, however, so far as I am concerned, the client does not own the file and has no right to the electronic drawing. If the client wishes to have an electronic copy of the drawing, then I will provide one, but it will have to be spelled out in the contract for services.
When I am hired for a project, I am hired to provide a set of plans, when the client receives their plans, the service has been fulfilled.
vinnyg
« Reply #5 on: August 22, 2007, 04:38:39 PM »
So, if said client wants to do remodeling of the initial project somewhere down the
road, he will have to start at square one to do Acad drawings, even if he offers to pay
extra for the cad files?
vinny
« Reply #6 on: August 22, 2007, 04:43:49 PM »
vinny
No, if he pays extra for the cad files or has negotiated the cad files as part of the contract, then he will get them. If not, I don't give them.
The simple reason is liability
a) I draw a set of plans to meet all codes and requirements
b) contractor decides that he doesn't need that big of a beam, has his guy change the beam size, he leaves my name on the plans
c) beam fails, I have to spend money defending myself
Nope ... not gonna happen
Guest
« Reply #7 on: August 22, 2007, 04:44:39 PM »
vinny
If its not written out in the original contract, or unless they come to some sort of agreement, then, yeah, he'd probably be SOL.  However, I personally don't see that happening much.  I've seen a lot of companies give copies of files (as-builts) simply because it's good for the business relationship.  Maybe get the next big job.
« Last Edit: August 22, 2007, 04:50:02 PM by Matt W »
« Reply #8 on: August 22, 2007, 04:46:12 PM »
Oh .. nevermind most clients of mine (homeowners) will not have a way to use the files anyway
sinc
« Reply #9 on: August 22, 2007, 04:50:49 PM »
We're the exact opposite.  As a survey firm, we explicitly state in our contract that we expect to get electronic files for all construction surveying.  If we do not, then the client must pay additional charges to recreate the files, if it is even possible.  So far, this threat has been enough to ensure that we always get electronic files (except for in one instance, where the client paid to have us recreate everything).  We also need the signed paper copies, and the signed paper copies are what holds in the case of dispute.  So we must be careful not to blindly use the electronics, but it can save considerable time, and therefore saves the client considerable expense.
Similarly, if we do a design survey, we always make electronic files available to the client.  We would much prefer that the engineers use our electronics, rather than go through the error-prone procedure of trying to recreate files from the printed copies.  It saves considerable headache if everyone involved in a project uses the exact same base linework, etc., rather than constantly ending up with slightly-different versions where lines sit hundredths apart from one DWG to the other.  We include disclaimers that we consider the only binding document to be the printed and signed drawings, but we also make the electronics available for use.
One of the things that we find very disturbing is the growing trend for plans to not contain enough information to recreate them without the original electronic files.  We think this is a very poor tendency, brought on by laziness, but it's getting to be more and more common.  It's now rare that we ever see a set of plans we could actually recreate from scratch if we had to.  And periodically, we have had people resist sending us their electronics.  So far, whenever that's happened, we pound the source with questions that illustrate that we CANNOT rebuild the drawings from the issued set of plans, and insist that they reissue a new set of plans that we can actually use.  And so far, when given the choice of sending us electronics or reissuing plans, they've chosen to send us electronics every time.
The funny thing we've noticed, though, is that whenever we have a really hard time getting the electronic files, they always turn out to be real garbage when we finally see them...   :-D
Arizona
« Reply #10 on: August 22, 2007, 05:41:47 PM »
As a company that utilizes the services of many contractors, we typically require the electronic files.
This is written into the contract with the standard deliverables stating our specific requirements (including any Cad specific issues/standards, etc...). Companies are given (approx.) 3 attempts to get it right or they are removed from the bidding list. As a customer, we have specific demands or we go elsewhere. So remember who pays your bills... the customer.
Make certain your contract clearly states your conditions and theirs, this way there aren't the hidden surprises. Which in some cases are simply better to give in to, for purely business reasons. Word of mouth travels very quickly in a small world. :-)
Unless you have customers lined up out the door, be willing to negotiate to keep that customer.
JMO.. :-)
Josh Nieman
« Reply #11 on: August 22, 2007, 05:54:56 PM »
Oh, yea, if you're a subcontractor and the guys you got the job from ask for your electronic files... I can definitely see that you would need them .dwgs!  We act the same way with our consultant subs... they go both ways, we send them dwg's that are required to work from, and they send us their when it's necessary.
I was just thinking of the end-client, only..
but either way it's all in the contract demands, still.
M-dub
« Reply #12 on: August 22, 2007, 06:01:39 PM »
I should have mentioned that I do agree that it should be in the original contract with the vendor.  If electronic files are not requested at project closeout, I blame the engineers for that.
Greg B
  • Tell me a Joke!
« Reply #13 on: August 23, 2007, 09:28:01 AM »
You guys realize that pretty much each time you say it's written into the contract.
The electronic file is owned by the architect.  It is the choice of the architect to contract/give/sell that file or not.
Josh Nieman
« Reply #14 on: August 23, 2007, 09:35:02 AM »
We don't have architects in our jobs 99% of the time :)
(not everyone is as lucky as us, I know)
*runs*
