Author Topic: Recommend a Drafting Standards BOOK  (Read 4639 times)
tgraham
« on: August 21, 2007, 03:22:06 PM »
I have been placed in charge of creating standards for a drafting department that does not have any documented standards.  What book would you recommend referencing while I develop these standards?????
SDETERS
Re: Recommend a Drafting Standards BOOK
« Reply #1 on: August 21, 2007, 03:29:43 PM »
What kind of work do you do?  Mechanical?
tgraham
« Reply #2 on: August 21, 2007, 03:45:58 PM »
A mixture of mechanical and architectural.  We draw commercial windows, storefronts and curtain wall.
hudster
« Reply #3 on: August 22, 2007, 03:25:12 AM »
I wouldn't use any book, look at what you do now and develop from there. A good set of standards will take in how you do things now. Change too much and people won't work to the standards.
Your standards should also continually develop.
Avanti
« Reply #4 on: August 22, 2007, 07:22:55 AM »
I found some great sources on the web.  I finally settled on the one created by Harvard to use as a guide.  The hardest part is deciding what works best for your company.
Guest
« Reply #5 on: August 22, 2007, 09:11:21 AM »
And here it is...
