Author Topic: Blip mode on/off  (Read 21979 times)
yyou
Blip mode on/off
« on: July 14, 2004, 06:09:46 PM »
I usually have my blip mode on.  It does not bother me.  On or off I don't even notice.  I only notice when I need them to be on and they are not.  When do I need them?   When I need to modify a bunch of similar entities, it helps me to see which one I already did.
Blip mode on/off
« Reply #1 on: July 14, 2004, 08:52:45 PM »
Blipmode is ok, but I sometimes find myself trying to erase those confounded tics only to realize they are blips, not linesor points in the drawing
Craig
Blip mode on/off
« Reply #2 on: July 14, 2004, 08:54:20 PM »
Blipmode off for me all the time. They are more of an annoyance for me
Slim©
  • The Dude Abides...
Blip mode on/off
« Reply #3 on: July 14, 2004, 08:57:11 PM »
Always off
Dent Cermak
Blip mode on/off
« Reply #4 on: July 14, 2004, 10:55:55 PM »
I HATE BLIPMODE!! Why didn't they get rid of that rather than all the stuff I use everyday!! ALL the good stuff from 14 didn't make it to LDD3. Thank goodness for the retired list!!
daron
Blip mode on/off
« Reply #5 on: July 15, 2004, 08:30:32 AM »
I agree. They should've done away with blipmode, but instead they semi-remove tracking and replace it with temp tracking. It's not the same. Tracking was so cool. You could set objects on a point, then move that point and keep moving it until you got what you were looking for. It seems odd to need that, but there was a time where I did need it, then they went and hid it away. It probably doesn't even exist anymore.
Blip mode on/off
« Reply #6 on: July 15, 2004, 12:25:49 PM »
I never used traking... it was always getting in the way of my snap settings.....
Back on track....
I no longer use blipmode
M-dub
Blip mode on/off
« Reply #7 on: July 15, 2004, 12:35:37 PM »
Quote from: Dent Cermak
Cheers, Dent!  What's the friggin' point?
I actually created a button in our menu just to shut them off...Guess which one...
Blip mode on/off
« Reply #8 on: July 15, 2004, 12:46:59 PM »
Why dont you update that button with this:
(setvar "blipmode" (boole 6 (getvar "blipmode") 1))
CADaver
Blip mode on/off
« Reply #9 on: July 15, 2004, 12:53:38 PM »
Quote from: Daron
As indicated by the first post in this thread, some folks still use it.
Prior to fast regens, toggling blipmode on and off was a totally transparent "REDRAW", but I haven't used it since.
yyou
Blip mode on/off
« Reply #10 on: July 15, 2004, 12:59:27 PM »
:shock:  Wow, overwhelming.  Autodesk should look at this topic.
M-dub
Blip mode on/off
« Reply #11 on: July 15, 2004, 01:09:39 PM »
Quote from: Se7en
Thanks, but I'd only use that if I wanted them to turn blipmode back on.  I only want them to turn it off...
(I know I'm letting my personal opinion interfere with the operation of everyone, but I hate blips!!!!!
M-dub
Blip mode on/off
« Reply #12 on: July 15, 2004, 01:10:08 PM »
Quote from: yyou
Likely wouldn't make any difference whatsoever... :roll:
Blip mode on/off
« Reply #13 on: July 15, 2004, 01:18:29 PM »
Heh, did you run it?
t-bear
Blip mode on/off
« Reply #14 on: July 15, 2004, 01:25:14 PM »
Actually, it's interesting to see that someone found a use for a function that everyone else HATES.... Just shows to go that there are a million ways to do anything in CAD.....COOL, eh?
