Author Topic: CommandComplete Tool from autodesk  (Read 5054 times)
Glenn R
« on: August 19, 2007, 07:43:54 AM »
Is it just me, or is anybody else thinking "Hello!?! Existing functionality...tab key anyone"..?
Nathan Taylor
Re: CommandComplete Tool from autodesk
« Reply #1 on: August 19, 2007, 07:13:43 PM »
I did.
Glenn R
« Reply #2 on: August 19, 2007, 07:39:51 PM »
Glad I'm not the only one.
If this is the sort of thing that will come out of 'Autodesk Labs', it's a joke and they may as well shut it down.
I still can't believe it actually... :-o :-o :-o
MickD
« Reply #3 on: August 19, 2007, 07:58:31 PM »
I personally would rather create a 2 key shortcut in the pgp file than look at such a distraction, like the tool tips and entry boxes that follow the mouse around, I would switch it off, but that's just me.
<edit> it's Monday!</edit>
« Last Edit: August 19, 2007, 08:16:53 PM by MickD »
- John Carmack
- J.R.R. Tolkien
Nathan Taylor
« Reply #4 on: August 19, 2007, 08:14:51 PM »
I really like the tab key functionallity for commands I don't use often. Especially long command names from the vertical products. Like Mick and probably hundreds of others I find the new tool an annoyance.
MickD
« Reply #5 on: August 19, 2007, 08:20:38 PM »
Yes, as Glenn basically pointed out, it is time wasted that could have been better spent on something more useful to the end user or developers.
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #6 on: August 19, 2007, 08:23:10 PM »
Spot on Mick.
LE
« Reply #7 on: August 19, 2007, 08:49:38 PM »
(did not have an idea about 'Autodesk Labs')
« Last Edit: August 20, 2007, 10:54:09 PM by LE »
Techno Destructo
« Reply #8 on: August 21, 2007, 01:51:27 AM »
I think it’s a good idea.
Now should it have been at the top of there list?
That’s the real question.
Maybe just me but the auto complete is would be quicker to identify a command you were not to sure about than hitting tab again and again.
Although a small and perhaps trivial app it does help AutoCAD appear as though it’s trying to keep their products up-to-date in appearance and abilities with other newer applications (and I don’t just mean CAD).
Perception is everything.
Glenn R
« Reply #9 on: August 21, 2007, 07:35:45 AM »
And that perception relies on you at least knowing the first letter (so autocomplete can kick in) of "that command you weren't sure about"
Dave R
« Reply #10 on: August 21, 2007, 08:20:22 AM »
No. It will find the commands containing the letters you type (See screenshot).  Still a waste of time though IMHO. You can achieve much more speed by editing the PGP file or defining your own 1,2 or 3 letter macros.
Glenn R
« Reply #11 on: August 21, 2007, 08:44:39 AM »
That's exactly my point. You have to know what to type to begin with.
LE
« Reply #12 on: August 21, 2007, 11:05:49 AM »
Glenn;
You know.... I remember hearing about the tab key ability to complete the command name some where but never put any attention to that, when I first read the above - did not have an idea of what you were talking about.... well now I understand what you are saying....
Jeff_M
  • C3D user & customizer
« Reply #13 on: August 25, 2007, 08:19:35 PM »
.... when I first read the above - did not have an idea of what you were talking about.... well now I understand what you are saying....
Ditto here. I never knew about the Tab function until I read this thread.
