Kerry,
The user needs to move attribs from a few blocks, but they are BOM numbers from valves and pumps and they are drawn by a vertical we use here all over the block itself. So I made an "easy to select” button for my collages. But now 'they don't know to what part that number belongs (if there are more on the same spot, as they are in top view of an installation branch).
So I wanted to show the information of that item (is it the butterfly valve, or the pump and so). I read that out of the block where attrib belongs to. So it is a short string that I want to show while the atrrib is moved.
I hope I did not confuse more than I explained
Thank's Bernd
