Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
The Third Dimension
Topic:
Visual Styles per object
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Visual Styles per object (Read 3314 times)
Guest
Guest
on:
August 16, 2007, 01:56:40 PM »
Is it possible to assign (for a lack of a better term) different visual styles to different objects? For example, I've got a mechanical plan (ductwork) and would like to show the walls using the X-Ray VS and the ductwork using the Conceptual or Realistic VS to really put the focus on the ductwork. I could apply a glass material to everything except for the ductwork, but that's just going to kill the computer; showing it in a "rendered" type view.
Any ideas?
Logged
deegeecees
Guest
Re: Visual Styles per object
Reply #1 on:
August 16, 2007, 02:01:11 PM »
I'm not sure what you're asking, but from what I surmized, you just need some contrast. For renders, if I want something to stand out, I use a grey for all background objects, and red for objects in focus.
Hope it helps.
Logged
Guest
Guest
Reply #2 on:
August 16, 2007, 02:08:57 PM »
I don't really need it for rendering....more of a "visual on screen check" to make sure ducts and pipes and what not aren't in conflict with anything else.
Logged
Josh Nieman
Guest
Reply #3 on:
August 16, 2007, 02:24:12 PM »
sorry, but no
I really wish it could happen for the reasons you state, pretty much.
I also wish you could output to an image file, something like a render, but using a visual style only, so that the image resolution is not constrained to screen resolution. Sometimes a good visual style is better as a non-realistic-rendering for some preliminary sketch type thing.
Logged
Guest
Guest
Reply #4 on:
August 16, 2007, 02:26:16 PM »
Quote from: Josh Nieman on August 16, 2007, 02:24:12 PM
sorry, but no
That's the conclusion I was coming to based on what I was seeing. *sigh*
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
The Third Dimension
Topic:
