Author Topic: All Layers to ByLayer  (Read 7959 times)
Re: All Layers to ByLayer
« Reply #15 on: August 16, 2007, 03:03:47 PM »
I did a similar thing in lisp a few years ago, except it goes beyond what you can do with the Properties Palette. Such as unlocking any unlocked layers first, includes all objects in all layouts and in all blocks, then resets any locked layers.
Guest
« Reply #16 on: August 16, 2007, 03:07:09 PM »
Wasn't that "All2ByLayer"?  I think I used/modified something like that of yours, but alas, now that 2008 has SETBYLAYER, well..... I just don't need it anymore.  I hope you understand.  It's not you; it's me.   :lol:
deegeecees
« Reply #17 on: August 16, 2007, 03:07:16 PM »
David Hall
  • Automatic Duh Generator
« Reply #18 on: August 16, 2007, 03:08:31 PM »
Here is what I use, modify to suit
Public Sub Everythingbylayer()
      Dim objSelected As Object
      Dim OBJSELSET As AcadSelectionSet
      Dim N As Integer
      On Error GoTo ERR_HAND
      ThisDrawing.SetVariable "CECOLOR", "BYLAYER"
      ThisDrawing.SetVariable "CELTYPE", "BYLAYER"
      Set OBJSELSET = ThisDrawing.SelectionSets.Add("EBL")
      OBJSELSET.Select acSelectionSetAll
      For Each objSelected In OBJSELSET
            objSelected.color = acByLayer
            objSelected.Linetype = "ByLayer"
            objSelected.Lineweight = acLnWtByLayer
            objSelected.Update
      Next
      ThisDrawing.SelectionSets.Item("EBL").Delete
      ZoomExtents
      ThisDrawing.Application.Update
Exit_Here:
      Exit Sub
ERR_HAND:
      Select Case Err.Number
            Case -2145320851
                  ThisDrawing.SelectionSets("EBL").Delete
                  Resume
            Case -2145386413
                  Resume Next
            Case Else
                  MsgBox Err.Number & " " & Err.Description
      End Select
End Sub
David Hall
« Reply #19 on: August 16, 2007, 03:10:02 PM »
This is worth a look
Wow, I forgot all about that!  Cool blast from the past, thanks DGCs
David Hall
« Reply #20 on: August 16, 2007, 03:12:35 PM »
I just looked at SETBYLAYER, and I had everything but the material and plot style options.  It also processes blocks, FYI, just in case you miss the prompt.  Some of my blocks are hard coded to layers on purpose
Guest
« Reply #21 on: August 16, 2007, 03:13:35 PM »
Nested blocks, too!
ML
« Reply #22 on: August 16, 2007, 03:18:41 PM »
Yes
Matts code did work fine
I had forgotten to put some objects in my drawing to test it  DUH  LOL
I will certainly keep it for future use
And yes, of course you could do a Ctrl A to select all objects, then choose Bylayer from the pulldown
Dam intellect  LOL
Thanks Matt
« Reply #23 on: August 16, 2007, 03:20:27 PM »
Guest
« Reply #24 on: August 16, 2007, 03:25:21 PM »
Thanks Matt
You're welcome.
You got plenty of good solutions here, so use whatever works best for you.
ML
« Reply #25 on: August 16, 2007, 03:32:54 PM »
Yes
Matt yours worked well, I was making the silly mistake of trying to change a lyer's property to bylayer.
Well, that won't work because Bylayer is the object's property and you got it.
Yes, your code worked fine
I saved the above code as well because I like how he applied the selection set to achieve the same result with a bit more functionality
Bryco
« Reply #26 on: August 16, 2007, 11:30:26 PM »
To be complete you need to add an Mtext to bylayer function (As in make the text inside the mtext bylayer). I've found some client drawings have all their mtext forced to another color.
Yuk.
