Author Topic: All Layers to ByLayer  (Read 7904 times)
ML
« on: August 16, 2007, 12:51:34 PM »
This one should be really easy but for some reason I am still getting an error
Does anyone see the problem???
Thank you
Sub AllLayersToByLayer()
Dim layer As AcadLayer
For Each layer In ThisDrawing.Layers
 layer.color = acByLayer
Next layer
End Sub
Guest
Re: All Layers to ByLayer
« Reply #1 on: August 16, 2007, 12:58:21 PM »
.COLOR is obsolete.  .TRUECOLOR is the new replacement.
What version of AutoCAD are you using?  2008 has a command called SETBYLAYER which you might want to look into.
    Dim color As AcadAcCmColor
    Set color = New AcadAcCmColor
    With color
        .ColorMethod = acColorMethodByACI
        .ColorIndex = "256"
    End With
        layer.TrueColor = color
    Next layer
End Sub
ML
« Reply #2 on: August 16, 2007, 01:04:43 PM »
WOW
That's interesting Matt
You would think out of the 3 books I have and the help screens, they would have had a proper example
Let me give it a whirl
Thank you
ML
« Reply #3 on: August 16, 2007, 01:10:04 PM »
Hi Matt
May be I wasn't totally clear; I am looking to change all layer colors to bylayer
Thank you
kpblc
« Reply #4 on: August 16, 2007, 01:49:58 PM »
Did i have right understand? Change layer colors to ByLayer?
Of course you can do it but this could crash AutoCAD or dwg file (can't open it next time). I receive this error one time and have no wishes to repeat it.
Layer objects can't be with color ByLayer or ByBlock. You have to set color by ACI (from 1 to 255) or TrueColor.
« Last Edit: August 16, 2007, 01:51:13 PM by kpblc »
Sorry for my English.
ML
« Reply #5 on: August 16, 2007, 01:59:55 PM »
Ahh
You make a good point
You would need to grab all the objects (entities) in the drawing and change the object names to ByLayer
I believe
Thank you
Guest
« Reply #6 on: August 16, 2007, 02:06:36 PM »
So you want all of the objects to be color bylayer, right?  Example: A line is drawn on layer "TEMP" and layer "TEMP"'s color is blue, but the line shows as red, you want that line's color property to be changed to BYLAYER instead of 1 (red), correct?
If you're using 2008, SETBYLAYER is by far the best/fastest way to accomplish this.
If not, we'll have to come up with something (unless somebody has already rolled one that they'd like to pass around).   ^-^
ML
« Reply #7 on: August 16, 2007, 02:42:58 PM »
I am using 2006 and it doesn't exist in there :(
I tried this little bit of code:
Dim Obj As Object
For Each Obj In ThisDrawing.ModelSpace
 Obj.color = acByLayer
Next
End Sub
It says, get all objects in Modelspace and make them to Bylayer
ML
« Reply #8 on: August 16, 2007, 02:43:34 PM »
But it is still not working
deegeecees
« Reply #9 on: August 16, 2007, 02:47:26 PM »
Non-programmatic way:
Select all objects, then in the properties dialog, select "Color", "ByLayer".
ML
« Reply #10 on: August 16, 2007, 02:47:58 PM »
BOOOO!
You are no fun  LOL :)
Guest
« Reply #11 on: August 16, 2007, 02:48:22 PM »
Try this.... (or use what DGCs suggests)
    Dim obj As AcadEntity
    With color
        .ColorIndex = "256"
    End With
    For Each obj In ThisDrawing.ModelSpace
        obj.TrueColor = color
    Next obj
End Sub
deegeecees
« Reply #12 on: August 16, 2007, 02:48:57 PM »
I know, sometimes I feel like a wet blanket.
ML
« Reply #13 on: August 16, 2007, 02:55:43 PM »
No, I agree with you
I use to program just for fun, now I generally have a rule which is program out of nec.
However, somone earlier asked if you can globally change all objects to bylayer at once, so the intellect kicked in  :-(   LOL
I thought it would take me 5 minutes to put together but it obviously didn't LOL
There are somethings you can do.
I could use the filter command in acad and ask him specifically what layers he runs into this the most with, then create a filter that he could run.
It's no big deal really, I am just curious now
deegeecees
« Reply #14 on: August 16, 2007, 03:03:26 PM »
Matts code is what you need then.
