Author Topic: Close Drawing question in lisp  (Read 5234 times)
V-Man
« on: July 14, 2004, 09:25:06 AM »
How do you get around the nagging question "Really want to discard all changes to drawing? <N>
in lisp
(command ".close" "Y") ;; does not work
« Reply #1 on: July 14, 2004, 09:30:19 AM »
Are you working in MDI mode?
V-Man
« Reply #2 on: July 14, 2004, 09:31:35 AM »
Yes
« Reply #3 on: July 14, 2004, 09:33:46 AM »
So you want to close one of the _other_ dwg's?
V-Man
« Reply #4 on: July 14, 2004, 09:35:54 AM »
Yes, I have a routine that will wblock out the currect drawing to create a clean drawing. I then want to close the drawing and DO NOT save changes.
(defun C:Cleanwblock ()
   (princ "\nwMake a New Clean Drawing")
   (setvar "FILEDIA" 0)
   (setvar "CMDDIA" 0)
   (setvar "CMDECHO" 1)
   (command "-layer" "on" "*" "thaw" "*" "unlock" "*" "")
   (command ".regen")
   (if (setq jset (ssget "x"))
         (setq jdwg (getvar "DWGNAME"))
         (setq jpath (getvar "DWGPREFIX"))
         (setq jfile (strcat jpath jdwg))
         (if (findfile jfile )
            (command "-wblock" jfile "Y" "" "0,0,0" "p" "" "N")
            (command "-wblock" jfile "" "0,0,0" "p" "" "N")
      (princ "\nNo Entities to Wblock")
   (setvar "FILEDIA" 1)
   (setvar "CMDDIA" 1)
   (command "close" jfile) ;;<----This does not work..
SMadsen
« Reply #5 on: July 14, 2004, 09:45:33 AM »
(command "VBASTMT" "ThisDrawing.Close(FALSE)")
could be a quit workaround.
V-Man
« Reply #6 on: July 14, 2004, 11:01:35 AM »
That works. Thanks for the help.
SMadsen
« Reply #7 on: July 14, 2004, 11:04:57 AM »
Oops typo .. 'quick' not 'quit'
« Reply #8 on: July 14, 2004, 11:38:33 AM »
Quote from: dvarino
- dvarino
I don't get it!!
When I run this I get a dwg with nothing in it :-/
V-Man
« Reply #9 on: July 14, 2004, 11:50:31 AM »
I don't get it!!
It works fine here.
« Reply #10 on: July 14, 2004, 11:59:26 AM »
Quote from: dvarino
I don't get it!!
It works fine here.
Ok. What do you get? What version of ACAD are you running this in?
V-Man
« Reply #11 on: July 14, 2004, 12:09:11 PM »
When I run the command it selects everything in the CAD file and wblocks it out on top of itself then the routine closes the file and DOES NOT save changes because if it did it would overwrite what I just wblocked and the drawing would be BLANK
Autocad Map5
Command: (getvar "acadver")
"15.06"
