Author Topic: Color of Attributes in blocks  (Read 8992 times)
PHX cadie
Re: Color of Attributes in blocks
« Reply #15 on: August 15, 2007, 11:09:30 AM »
Whoa   :-o
All you guys are just too darn good!
I am in awe, THANKS!
Acad 2013 and XM
deegeecees
« Reply #16 on: August 15, 2007, 11:20:04 AM »
If you want to run one of the examples in a batch, this works fairly well. Just need to add the commands where it it says "COMMANDS FOR BATCH GO HERE".
(DEFUN C:batch_anything ()
;;;;;;;;;;;;;;;;;;;;;;;;;Select directory to be processed
(setq dfil (getfiled "Select A File In The Directory You Want To Batch Process" "p:/" "dwg" 0))
(setq wutdir (vl-filename-directory dfil))
(setq wutfiles (vl-directory-files wutdir "*.dwg"))
(setq scrfile (open "c:\\scrfile.scr" "w"))
(close scrfile)
(setq scrfile (open "c:\\scrfile.scr" "a"))
(foreach n wutfiles
(setq n2 (strcat "\""wutdir "\\" n "\""))
(setq n2 (vl-string-translate "\\" "\\" n2))
(setq scrline (strcat "open" " " n2 " " "(load\"batch_core\")" " " "batch_insert" " " "qsave" " " "close"));;;;;;;COMMANDS FOR BATCH GO HERE
(write-line scrline scrfile)
(close scrfile)
(command "script" "c:\\scrfile")
(princ "\n***Batch complete.***")
);;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;DEFUN
« Reply #17 on: August 15, 2007, 11:31:14 AM »
This will put all attributes to color bylayer (if the layer is not locked) and update the block definition.
Spawned from:
http://www.theswamp.org/index.php?topic=16987.msg206466#msg206466
(defun c:rjp-att2bylayer (/ blkobj lays ss)
  (setq lays (vla-get-layers
ss   (ssget "x" '((0 . "INSERT") (66 . 1)))
  (if ss
      (setq ss
     (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))
      (mapcar
'(lambda (b)
   (if (eq (vla-get-lock (vla-add lays (vla-get-layer b)))
   :vlax-false
       (mapcar
'(lambda (a)
    (vla-put-color a 256)
(vlax-invoke b 'getattributes)
       (vlax-for blkobj (vla-item
  (vla-get-blocks
  (vla-get-name b)
(mapcar
   '(lambda (c)
      (vla-put-color blkobj 256)
     (princ (strcat "\n Block "
    (vla-get-name b)
    " on locked layer "
    (vla-get-layer b)
    " not updated..."
ss
Ron
CADaver
« Reply #18 on: August 15, 2007, 11:52:01 AM »
ahh cool, that's a keeper
A long time ago I built a "dummy" profile with a "dummy" menu that had nothing in it and a "dummy" MNL.  When I need to batch something, I'll modify the "dummy" MNL for the functions (including "save" and "close"), then just open a directory worth of files.
deegeecees
« Reply #19 on: August 15, 2007, 12:09:16 PM »
Thanks. With all the support I've gotten over the years, I figured I could give something back once in a while (although my expertise is basically hack mode).
PHX cadie
« Reply #20 on: August 15, 2007, 12:42:25 PM »
OK, I'm back in this because you guys are having way too fun  :-D
Problem 1 I did not mention:
Bylayer will not work because all the text attributes are forced yellow
Problem 2:
the sections have various names, ie bubble-left-up, bubble-up-left, etc, prob ~6 names for the sections bubbles depending on orientation.
So, will a script file with multiple file names work?
-insert oldblock=newblock
-insert oldblock1=newblock1
-insert oldblock2=newblock2 y [esc]
attsync oldblock
Don't think(?) using layers will work, (because they are blocks). Need to experiment w/ that one.
Right now I'm refedit, attsync, which knocks out 4-6 at a time, (tremendous help). You guys could prob use batchs/scripts and get this done in an hour.Its my lack of knowledge
 :oops:
Acad 2013 and XM
CADaver
« Reply #21 on: August 15, 2007, 12:51:41 PM »
Mulitple redefines should work a breeze in a script or a function
ATTSYNC will work with wildcards so ATTSYNC N * will sync 'em all.
When you redefine the block, move the attributes to a layer and make it whatever color you want.  ATTSYNC should overide the forced color.
« Last Edit: August 15, 2007, 12:52:53 PM by CADaver »
« Reply #22 on: August 15, 2007, 12:57:14 PM »
It will ....
« Reply #23 on: August 15, 2007, 01:12:17 PM »
Then your attributes were put on a wrong layer? If you run my routine, the attributes color should match the color of the layer they reside on...
PHX cadie
« Reply #24 on: August 15, 2007, 01:45:35 PM »
Hate agrue w/ Mr. Computer, but....
This is my script:
-insert SECT-MARKER=SECT-MARKER1 y [esc]
attsync SECT-MARKER
This is Mr. Computers reply:
-Command: _SCRIPT
Enter script file name <H:\Client\Phoenix_PHXC\7360A10\DWGS\XREF
Files\91-S-017-EPSSECS.scr>: "C:\Greg\MISC\LISP\UP05.SCR"
Command: -insert Enter block name or [?] <SECTION-MARKER1>:
"SECT-MARKER1.dwg": Can't find file in search path:
  C:\Documents and Settings\GDavis\My Documents\ (current directory)
  H:\Client\Phoenix_PHXC\7360A10\DWGS\XREF Files\
  L:\AutoCAD 2005\R16.1\enu\Support\
  L:\
  L:\BLOCKS\Symbol Manager\
  C:\Documents and Settings\carollo\Application Data\Autodesk\AutoCAD
2005\R16.1\enu\support\
  C:\Program Files\AutoCAD 2005\support\
  C:\Program Files\AutoCAD 2005\fonts\
  L:\FONTS\
  C:\Program Files\AutoCAD 2005\help\
  C:\Program Files\AutoCAD 2005\express\
  C:\Program Files\AutoCAD 2005\support\color\
  L:\LISP\
  L:\VBA\
  C:\Greg\MISC\
  C:\Greg\MISC\Bitmaps\
  C:\Greg\MISC\LISP\
  C:\Greg\
  L:\AutoCAD 2005\R16.1\enu\Support\Color\
*Invalid*
  C:\Greg\        .......yes it is
  H:\Client\Phoenix_PHXC\7360A10\DWGS\XREF Files\       .......yes it is
 :|  (but is my first attempt)
Acad 2013 and XM
PHX cadie
« Reply #25 on: August 15, 2007, 02:13:11 PM »
 :oops:
<Note to self use correct file name>
 :oops:
Sorry,
Now to really screw things up  :evil:
Acad 2013 and XM
PHX cadie
« Reply #26 on: August 15, 2007, 05:32:19 PM »
No mass damage yet
It seems as though:
-insert det-MARKER=det-MARKER1 y [esc]
-insert BUB-DN-RIGHT=BUB-DN-RIGHT1 y [esc]
ATTSYNC N *
only inserts the first line (SECT-MARKER). It asks for a y scale and insertion point and inserts only the revised SECT-MARKER.
What am I missing?
Acad 2013 and XM
« Reply #27 on: August 15, 2007, 05:59:40 PM »
you do know that both blocks can have the same name, don't you ?
(command "-insert" "SECT-MARKER=c:/SECT-MARKER" )(command)
so you don't need the "Y"
« Last Edit: August 15, 2007, 06:13:43 PM by Kerry Brown »
« Reply #28 on: August 15, 2007, 06:49:42 PM »
Kerry, if the user wasn't around say prior to R10 they are not aware of the Block=Block command
PHX cadie
« Reply #29 on: August 15, 2007, 07:33:58 PM »
Yes, in the code I put a number 1 behind each revised block name. Is that what youre refering to?
I dont understand about the "Y". <edit....now I see it>
Acad 2013 and XM
