Author Topic: Color of Attributes in blocks  (Read 8956 times)
PHX cadie
Re: Color of Attributes in blocks
« Reply #45 on: August 16, 2007, 03:05:00 PM »
and I "Thank You" also.
Pls take note, (I start @7 finished ~10), in 3hrs I did what took a full day yesterday. It took 3 hours because of making individual files of corrected blocks, finding exploded blocks  :pissed: and wrong layers, etc. So 3 hrs verses 9 hrs......not too shabby!
Oh... wish you all could have seen the Boss's face when I brought it back.
I love guys  :-D
Acad 2013 and XM
« Reply #46 on: August 16, 2007, 03:38:50 PM »
deegeecees
« Reply #47 on: August 16, 2007, 04:07:13 PM »
My past and present bosses got used to that sort of thing (a little too used to it).
BTW you may want to edit your last post, so as not to confuse anyone.
deegeecees
« Reply #48 on: August 17, 2007, 12:02:01 AM »
and I love gals ;)
Ditto.
Just to clarify.
<Seinfeld> Not that there's anything wrong with that."</Seinfeld>
« Reply #49 on: August 17, 2007, 02:04:07 AM »
PHX, Ignore these guys .. I knew what you meant.
craigr
« Reply #50 on: August 20, 2007, 11:26:27 AM »
That's the problem with showing them something that you came up with or found on a disscussion board - When you run into a problem that you can't come up with a quicker fix, they get frustrated that you can't.
Sometimes it's better to keep your mouth shut and pat yourself on the back rather than asking them do it.
craigr
