- Smoke/Motor Sensor Do you have an example ?- Fire Damper This should be in CreateDamper.lsp ?- Fire & Smoke Damper Do you have an example ?- Sidewall Grill I actually have this partly coded just haven't finished it yet - Square-to-round Transition (<---- this one would be a popular one) This is in CreateTransition.lsp- Thermostat Is this normally a block? I have a block for it but I could easily create a routine for thisThose would be easy to code, plus they are a huge portion of HVAC design. Hope this helps
Here is a wall lisp someone in here helped with it (sorry I don't remember who)
