Author Topic: Arg!! Layer won't purge!  (Read 3346 times)
craigr
« on: July 13, 2004, 12:08:43 PM »
I am using LT98. I have copied a floor plan from one dwg to windows clipboad, then into the modelspace of my dwg. I then exploded, &  changed all items that I can find, to a layer called 'floorplan'. I then purged the dwg of all past layers. - One won't go away. It is called '-tblk'. I went to original dwg and turned that layer off before copying what I need. I have even erased what I have pasted into my title block, (so my model space is empty again), - erase;all;; and CAD says there is nothing there. - The '-tblk' layer won't purge. I don't have it selected as current layer, frozen, turned off, etc... - It SHOULD purge, but it won't. What am I missing? - craigr
Dommy2Hotty
« Reply #1 on: July 13, 2004, 12:16:15 PM »
Try doing a "_qselect" with the options "Apply to: Entire Drawing," "Object Type: Multiple," "Properties: Layer," "Operator: =Equals," "Value:-tblk," "How to apply: Include in new selection set."
See if anything comes up that way... :twisted:
craigr
« Reply #2 on: July 13, 2004, 12:18:49 PM »
'qselect' is apparently not available in LT98. - thanks anyway
ryandk
« Reply #3 on: July 13, 2004, 12:27:57 PM »
A third party utility called SuperPurge should work.  It will let you "hard" purge pretty much anything, even if something is on that layer.  It is made by a Manusoft, www.manusoft.com .  It is shareware but you can use it for free for 30 days last time I checked.
Ryan
Dent Cermak
« Reply #4 on: July 13, 2004, 12:31:19 PM »
ARE YOU SURE THAT ALL OF YOUR BLOCKS ARE PURGED ? You may still have an old block definition hanging around that uses that layer.
craigr
« Reply #5 on: July 13, 2004, 12:45:09 PM »
EVERYTHING is erased and the layer remains.
I downloaded & install Superpurge, it must not work with LT98 or LT200i. It said that the installation was successful, but neither program would recognize the commands 'spurge', etc...
Thanks anyway.
VerticalMojo
« Reply #6 on: July 13, 2004, 12:46:38 PM »
Copy everything and put it on a new drawing and leave that sucker behind......
CADaver
« Reply #7 on: July 13, 2004, 01:16:41 PM »
If it is frozen in a viewport, it won't purge.
« Reply #8 on: July 13, 2004, 02:16:53 PM »
If it is referenced by a non graphical entity or if there are old style polylines with a seqend entity that references it, then it will not purge.
Try wblocking the drawing to a new name and open the new drawing to see if it still exists. As a last resort, upload it to the lillypond and let one of the guru's here look at it..
VerticalMojo
« Reply #9 on: July 13, 2004, 02:21:36 PM »
upload it! Upload it!
http://theswamp.org/lilly.pond/
Andrew H
« Reply #10 on: July 14, 2004, 04:02:15 PM »
most of the time it is something referenced to that layer that will keep it in a drawing. wblock will probably work. if not post it to lilly and someone will fix it.
or e-mail it to me and i'll have a look.
andrewh@craigroberts.com
PDJ
« Reply #11 on: July 14, 2004, 06:02:14 PM »
Or do like I do and just put T-Bears initials in the "drawn by" block on the title block and blame it on him..
