Author Topic: Get column letters from a number...  (Read 3965 times)
terrycadd
« on: August 09, 2007, 06:48:10 PM »
I'm back!  Been kinda' busy at work.  I'm working on a function relating to gathering Excel information, and here is one of the functions that I feel can be simplified by you all.  I'm not sure if I needed the RoundUp: function, but the way I wrote it makes the values come out correct.  So I left it in anyway.  Any re-writes welcome.   :kewl:
Terry Cadd
; Number2Column - Returns the Column letter from a number
; Syntax example: (Number2Column 133) = "EC"
(defun Number2Column (Number# / Number1# Number2# RoundUp:)
  ;RoundUp: - Rounds up to even integers
  (defun RoundUp: (RealNumber~)
    (if (/= (fix RealNumber~) RealNumber~)
      (1+ (fix RealNumber~))
      (fix RealNumber~)
    );if
  );defun RoundUp:
  (setq Number1# (1- (RoundUp: (/ Number# 26.0))))
  (setq Number2# (- Number# (* Number1# 26)))
  (if (> Number1# 0)
    (strcat (chr (+ Number1# 64))(chr (+ Number2# 64)))
  );if
);defun Number2Column
Patrick_35
Re: Get column letters from a number...
« Reply #1 on: August 10, 2007, 07:10:37 AM »
try
(defun Number2Column (nb)
  (if (> nb 26)
    (strcat (chr (+ 64 (fix (/ nb 26)))) (chr (+ 64 (rem nb 26))))
    (chr (+ 64 nb))
(Number2Column 133) --> "EC"
(Number2Column 2)  --> "B"
« Last Edit: August 10, 2007, 07:19:26 AM by Patrick_35 »
gile
  • Marseille, France
« Reply #2 on: August 10, 2007, 07:13:36 AM »
Terry,
Your code works fine until 702 which returns "ZZ", but 703 returns "[A" instead of "AAA".
Patrick,
Your code works fine until 51 which returns "AY", but 52 returns "B@" instead of "AZ".
Here's another way, using a recursive form (assuming num is a strictely positive integer) :
(defun num2alpha (num / r)
  (if (< num 27)
    (chr (+ 64 num))
    (if (= 0 (setq r (rem num 26)))
      (strcat (num2alpha (1- (/ num 26))) "Z")
      (strcat (num2alpha (/ num 26)) (chr (+ 64 r)))
(num2alpha 702) -> "ZZ"
(num2alpha 703) -> "AAA"
(num2alpha (* 26 703)) -> "ZZZ"
(num2alpha (1+ (* 26 703))) -> "AAAA"
« Last Edit: August 10, 2007, 07:20:29 AM by gile »
Patrick_35
« Reply #3 on: August 10, 2007, 07:23:50 AM »
Comme le monde est petit  ^-^
Hi (gile)
Your lisp is good, except that the columns of Excel go only up to IV, that is to say (Number2Column 256)
Patrick_35
« Reply #4 on: August 10, 2007, 07:38:51 AM »
Exactly
(defun Number2Column (nb / i)
  (setq i (rem nb 26))
  (if (> nb 26)
    (if (zerop i)
      (strcat (chr (+ 63 (/ nb 26))) "Z")
      (strcat (chr (+ 64 (fix (/ nb 26)))) (chr (+ 64 i)))
    (chr (+ 64 nb))
(Number2Column 52) --> "AZ"
gile
  • Marseille, France
« Reply #5 on: August 10, 2007, 08:27:22 AM »
Exact, but I've done something more general (it's called "num2alpha" rather than "Number2Column"  :wink:), and if some new Excel release allows 1024 columns or more, I'm ready  :-D
Just for the fun, the reverse function
(defun alpha2num (str / n)
  (if (= 0 (setq n (strlen str)))
    0
    (+ (* (- (ascii (strcase (substr str 1 1))) 64)
  (expt 26 (1- n))
       (alpha2num (substr str 2))
« Last Edit: August 10, 2007, 10:06:39 AM by gile »
terrycadd
« Reply #6 on: August 10, 2007, 10:29:51 AM »
My version that I worked on yesterday was very limited to handle only the range from "A" to "ZZ".  The problem is sorta' like converting a number into a hexadecimal number base 16, only this equation is base 26.
I haven't tested the submissions above yet this morning, but I can tell right off that you guys are right on track.
Terry
