Author Topic: 3DSolid Threads  (Read 3905 times)
3DSolid Threads
« on: July 12, 2004, 02:20:39 PM »
Ok, I remember some time ago a thread (probably over at the now defunct site) about a proggie that would draw 3dSolid threads.. If anyone has it or something that is comparable I could use it....
t-bear
3DSolid Threads
« Reply #1 on: July 12, 2004, 04:09:50 PM »
Keith....I found this for starters....know I got sumpin better......
;;; 3DSPIRAL.LSP
;     Copyright (C) 1992 by Autodesk, Inc.
;     Permission to use, copy, modify, and distribute this software
;     for any purpose and without fee is hereby granted, provided
;     that the above copyright notice appears in all copies and that
;     both that copyright notice and this permission notice appear in
;     all supporting documentation.
;     THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;     WARRANTY.  ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;     PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;; DESCRIPTION
;;;   This is a programming example.
;;;   Designed and implemented by Kelvin R. Throop in January 1985
;;;   This program constructs a spiral. It can be loaded and called
;;;   by typing either "spiral", "3dspiral" or the following:
;;;   (cspiral <# rotations> <base point> <horiz growth per rotation>
;;;            <points per circle> <start radius>
;;;            <vert growth per rotation>).
(defun myerror (s)                    ; If an error (such as CTRL-C) occurs
                                      ; while this command is active...
  (if (/= s "Function cancelled")
    (princ (strcat "\nError: " s))
  (setvar "cmdecho" ocmd)             ; Restore saved modes
  (setvar "blipmode" oblp)
  (setq *error* olderr)               ; Restore old *error* handler
(defun cspiral (ntimes bpoint hfac lppass strad vfac
                / ang dist tp ainc dhinc dvinc circle dv)
  (setvar "blipmode" 0)               ; turn blipmode off
  (setvar "cmdecho" 0)                ; turn cmdecho off
  (setq circle (* 3.141596235 2))
  (setq ainc (/ circle lppass))
  (setq dhinc (/ hfac lppass))
  (if vfac (setq dvinc (/ vfac lppass)))
  (setq ang 0.0)
  (if vfac
    (setq dist strad dv 0.0)
    (setq dist 0.0)
  (if vfac
    (command "3dpoly")                ; start spiral ...
    (command "pline" bpoint)          ; start spiral from base point and...
  (repeat ntimes
    (repeat lppass
      (setq tp (polar bpoint (setq ang (+ ang ainc))
                      (setq dist (+ dist dhinc))
      (if vfac
          (setq tp (list (car tp) (cadr tp) (+ dv (caddr tp)))
                dv (+ dv dvinc)
      (command tp)                    ; continue to the next point...
  (command "")                        ; until done.
;;;       Interactive spiral generation
(defun C:SPIRAL (/ olderr ocmd oblp nt bp cf lp)
  ;;;;(setq olderr  *error*
  ;;;;      *error* myerror)
  (setq ocmd (getvar "cmdecho"))
  (setq oblp (getvar "blipmode"))
  (initget 1)                         ; bp must not be null
  (setq bp (getpoint "\nCenter point: "))
  (initget 7)                         ; nt must not be zero, neg, or null
  (setq nt (getint "\nNumber of rotations: "))
  (initget 3)                         ; cf must not be zero, or null
  (setq cf (getdist "\nGrowth per rotation: "))
  (initget 6)                         ; lp must not be zero or neg
  (setq lp (getint "\nPoints per rotation <30>: "))
  (cond ((null lp) (setq lp 30)))
  (cspiral nt bp cf lp nil nil)
(defun C:3DSPIRAL (/ olderr ocmd oblp nt bp hg vg sr lp)
  (initget 7)                         ; sr must not be zero, neg, or null
  (setq sr (getdist bp "\nStarting radius: "))
  (initget 1)                         ; cf must not be zero, or null
  (setq hg (getdist "\nHorizontal growth per rotation: "))
  (setq vg (getdist "\nVertical growth per rotation: "))
  (cspiral nt bp hg lp sr vg)
(princ "\n\tC:SPIRAL and C:3DSPIRAL loaded. ")
I'll keep lookin'.....
t-bear
3DSolid Threads
« Reply #2 on: July 12, 2004, 04:15:33 PM »
.....or this.......
; HELIX.LSP 8/89 Tony Tanzillo.
;Thanx to Andy Anderson for reviving this routine.....
; Draws 3D helical springs and coils of varying width.
; Generic front end, no validation of user input is done, and
; and no error handler is included.
(defun C:HELIX ( / cp od wi sa pt rt)
( (and (setq cp (getpoint "\nCenter point: "))
(setq ra (getdist cp "\nOutside radius: "))
(setq wi (getdist "\nCoil width: "))
(setq sa (getangle cp "\nStarting angle: "))
(setq pt (getdist "\nPitch: "))
(setq rt (getreal "\nNumber of rotations: ")))
(princ "\nGenerating helix...")
(helix cp (* 2.0 ra) wi sa pt rt)))
; Returns delta Z offset of a 2D or 3D point in the current UCS
(defun delta_z (pt z)
(list (car pt)
(cadr pt)
(cond ( (caddr pt) (+ (caddr pt) z)) (t z))))
; (helix )
; Back end for C:HELIX
; Note: SURFTAB1 controls resolution (number of segments/rotation)
(defun helix ( cp od wi sang pitch rot /
orad irad segs s_ang s_pitch bp iang w bm)
(setq segs (getvar "surftab1") ; SURFTAB1 controls resolution
s_ang (/ (* 2.0 pi) segs) ; included angle of segment
s_pitch (/ pitch segs) ; segment pitch (z offset)
iang (- sang s_ang) ; segment angle
bp (delta_z cp (- s_pitch)) ; segment pitch
orad (/ od 2.0) ; outer radius
irad (- orad wi)) ; inner radius
(setq bm (getvar "blipmode"))
(cond ( (setq w (> wi 0.0)) ; if helix width > 0,
(command "3DMESH" ; then start a 3DMESH
(fix (1+ (* segs rot))) 2)) ; M = 1 + segements * rotations
; N = 2 edges of the flat coil
(t (command "3DPOLY"))) ; otherwise, start 3D polyline
(repeat (fix (1+ (* segs rot))) ; and go for it
(command
(polar
(setq bp (delta_z bp s_pitch)) ; increment pitch
(setq iang (+ iang s_ang)) ; increment angle
orad )) ; outer radius
(cond (w (command (polar bp iang irad)))) ; if helix has width, then
) ; specify inner edge.
(cond ((not w) (command ""))) ; Stop if drawing a 3DPLINE.
(setvar "blipmode" bm)
......still diggin'.....[/quote]
3DSolid Threads
« Reply #3 on: July 12, 2004, 09:51:10 PM »
These are great.. I will see if they will do what I need in the AM... I may be able to modify them to produce a 3dSolid on the path generated by a 3dpoly, but I am not holding my breath
3DSolid Threads
« Reply #4 on: July 12, 2004, 10:49:43 PM »
The one i remembered had to do with Helix.lsp but ended up pointing here.
http://cadtutorforum.net/forum/viewtopic.php?t=477
t-bear
3DSolid Threads
« Reply #5 on: July 13, 2004, 08:29:44 AM »
Just to satisfy my curiosity, Keith.  why are you trying to draw threads?  The couple of feeble attempts I made some years ago were not the greatest, except in file size.  The word "HUGE" comes to mind.  with over 300 nuts, bolts and screws in a typ. assy, it was *really* counter-productive....
3DSolid Threads
« Reply #6 on: July 13, 2004, 10:11:34 AM »
Patent drawings... they are very particular in the view, thread pitch, depth.. etc... it must be shown and be to scale, submitted in ACIS Solid format ... I was thinking of doing it in TurboCAD because it is part of their mechanical package, but I don't want to do it if I don't have to.
t-bear
3DSolid Threads
« Reply #7 on: July 13, 2004, 01:00:05 PM »
That might end up being your best bet.  do you have access to a parametric...Inventor or SWX?
They handle this kind of solids geometry better than ACAD.....
3DSolid Threads
« Reply #8 on: July 13, 2004, 02:52:14 PM »
nope sure dont.... and I would have to purchase TurboCAD to do it too... I think I may be able to handle it with the proggies above.. we'll see
