Author Topic: Exporting to 3D Studio From Autocad  (Read 10652 times)
SDETERS
« on: August 06, 2007, 12:26:32 PM »
I am getting an error when trying to export a 3ds file from autocad
the error is the following
Object  has too many vertices and was not output
3D Studio file output completed
« Last Edit: August 06, 2007, 02:15:30 PM by SDETERS »
Josh Nieman
Re: EXPORTING TO 3D STUDIO FROM AUTOCAD
« Reply #1 on: August 06, 2007, 12:28:48 PM »
I don't know what your software setup is but can you open the dwg in 3dsmax and saveas a .3ds?
SDETERS
« Reply #2 on: August 06, 2007, 12:29:47 PM »
Sorry I am trying to export out of Autocad 2004
I imported a 3D model via solidworks via sat format
I go to export out of autocad and I get that error
This file will be opened in cinema 4d or something like that.
« Last Edit: August 06, 2007, 12:31:07 PM by SDETERS »
Josh Nieman
« Reply #3 on: August 06, 2007, 12:31:39 PM »
Also, a work around I have not tried (haven't run into the problem yet) but have read of is that 3ds format cannot contain a single object (not file, just object) with more than 65,000 faces so maybe if you just slice some of the larger objects (if this problem seems like it may produce the symptoms you're seeing) and then join them later?
SDETERS
« Reply #4 on: August 06, 2007, 12:32:56 PM »
Thanks I will have to try this
This file is going to an outside company so I would like to send the file as one so they do not have to put it together later.
Josh Nieman
« Reply #5 on: August 06, 2007, 12:33:59 PM »
Also, I don't know what type of facial accuracy you need, but facetres will control the density of faces on an object (whether a 1" sphere is represented by a 20-faced object or some object with 10,000 faces)
Think of those funky dice you see in hobby stores.  Once they get to about 20-sided dice and higher, that's basically a sphere controlled by how many sides they want on it... 20...50...100... whatever they go up to.  FACETRES in Autocad controls that...which'll help keep your objects as they should be.
Josh Nieman
« Reply #6 on: August 06, 2007, 12:35:27 PM »
Actually I'm going to have to add a "I think..." to that last post.  I'm not sure if FACETRES only controls the faces when Autocad RENDERS or has a HIDDEN visual style, or if it also extends to ALL facial computations like exporting...  someone else may need to confirm that, either which way.
SDETERS
« Reply #7 on: August 06, 2007, 12:45:58 PM »
DOOHHH nope
Facetres did not work
too many vertices still
Josh Nieman
« Reply #8 on: August 06, 2007, 12:48:57 PM »
crud.  must just be for render/display purposes within Autocad then.
I think that 65k facial ceiling is going to bite you in the butt.  You can always split the objects like I said, download a 30-day trial of 3dsmax, and join them by opening the .3ds in 3dsmax and resaving it :p
...of course that's not a permanent solution
...and if you had a working copy of 3dsmax I guess you would just open the dwg natively instead of exporting...
...ok I'm not much help past this point  :lol:
SDETERS
« Reply #9 on: August 06, 2007, 12:52:36 PM »
Thanks for the tips
I can play some more and see what works
We have PRO-E so I am going to try to save it as a wavefront file
Cross my fingers on this one
SDETERS
Re: Exporting to 3D Studio From Autocad
« Reply #10 on: August 06, 2007, 03:14:20 PM »
Will the trial version of 3D studio max be able to open the DWG file?
Then I export to 3d studio out there?
Shane
Josh Nieman
« Reply #11 on: August 06, 2007, 03:34:28 PM »
Yea, I'm not sure about before Autodesk bought 3dsmax, but I know since they purchased the product, it has included native DWG import/export capabilities.  It actually has several options to control the quality of the import, including keeping objects on proper layers, being able to assign materials by those layers, and being able to control the welding/"facetres" (forget the term 3dsmax uses) when you import.  I found that when bring in a project of an offshore platform including all structural, mechanical and piping layers which totalled around 130 or so, I'd guess, the import and subsequent work was very easy to handle.
SDETERS
« Reply #12 on: August 06, 2007, 04:40:36 PM »
Ok finally got it I think  When I exported out the first time I had everything on layer 0   :realmad:
I had to export out Solidworks assembly to sat file  The last time I exported out as a part.
Then in Autocad I had to assign a layer to each part and then the export worked
« Last Edit: August 06, 2007, 04:46:08 PM by SDETERS »
SDETERS
« Reply #13 on: August 08, 2007, 09:51:52 AM »
This 3ds studio exporting is for the birds.  The parts I am trying to export is to big for Autocad 3ds studio export.  I can not break it up because the end user does not know how this part goes back together.  I downloaded the 3D studio last night and tried to import the file as an iges and it locked my computer up.  I tried to open the dwg and half of the parts do not show up.
So this is what I am looking for now.
I need to get a STEP IGES or Parasolid into one of the following formats
Any suggestions?  I found this program called polytrans from okino.  Is this program any good?  Any one have experience with this program?
CINEMA 4D scenes ('.c4d'), catalogs ('.cat'), preferences ('.prf')
       3D studio R4 ('.3ds')
       DEM scenery files ('.dem')
       DXF to AutoCAD R12
       Illustrator paths as polygons ('.ai', '.art', '.eps')
       LightWave 3D (.lwo, .lwx) and LightWave 6 objects
       QuickDraw 3D ('.3dm') binary only, not ASCII
       Wavefront ('.obj')
« Last Edit: August 08, 2007, 09:54:18 AM by SDETERS »
Josh Nieman
« Reply #14 on: August 08, 2007, 09:54:57 AM »
Sorry I don't know anything about it.
Since you have 3dstudio downloaded, can you try cutting the objects in Autocad and then joining/unioning them in 3ds
