Author Topic: Can I use VBA method to get vlax-ldata-put value?  (Read 5072 times)
fools
  • China
« on: August 05, 2007, 09:05:11 PM »
(vlax-ldata-put "mydict" "mykey" "test")
Use below codes,I can find the "dict" and "key" ,but where is the value?
(vla-item (vla-item (vla-get-Dictionaries (vla-get-Activedocument(vlax-get-acad-object))) "mydict") "mykey")
Good good study , day day up . Sorry about my Chinglish .
Re: Can I use VBA method to get vlax-ldata-put value?
« Reply #1 on: August 05, 2007, 11:36:07 PM »
AFAIK, ldata is only accessible with lisp, which is one reason many people have preached to not use it.
« Reply #2 on: August 06, 2007, 12:02:30 AM »
The insidious thing about ldata is that it's platform (LISP) and version centric, at
least early incarnations (cough, r14) which caused much grief when folks went to
use the data in newer versions of AutoCAD because it was inaccessible. Pure evil.
Best strategy is to use the standard data containers: xdata, xrecords, dictionaries
and xdictionaries ...
jbuzbee
« Reply #3 on: August 08, 2007, 11:33:55 PM »
+1
James Buzbee
Windows 8
