Author Topic: Can Spaces be used in "GETSTRING"?  (Read 5913 times)
A_LOTA_NOTA
« on: August 03, 2007, 01:29:12 PM »
Can flags be set to let the user enter spaces when promted by "GETSTRING"? Is so how?
(setq DwgName (getstring "\nEnter Drawing Name: "))
I want the user to be able to enter this "9513C A"
Guest
Re: Can Spaces be used in "GETSTRING"?
« Reply #1 on: August 03, 2007, 01:31:56 PM »
Yup!
(setq s (getstring T "What's your full name? "))
A_LOTA_NOTA
Having a problem with leading spaces.
« Reply #2 on: August 03, 2007, 01:34:44 PM »
I have tried that but it doesn't work if the user adds a leading space by mistake. Not on my machine anyway.....
« Last Edit: August 03, 2007, 02:35:25 PM by A_LOTA_NOTA »
CADaver
« Reply #3 on: August 03, 2007, 02:41:57 PM »
Works fine on mine.  did you add the "T"??
A_LOTA_NOTA
« Reply #4 on: August 03, 2007, 02:46:58 PM »
Yes... I even tried the example he posted.
Gets hosed if I add a leading space.
« Reply #5 on: August 03, 2007, 02:52:38 PM »
(vl-string-trim " \t\n\r"
    (getstring t "Enter stuff: ")
Guest
« Reply #6 on: August 03, 2007, 02:53:36 PM »
No it doesn't...
(defun C:GetGString ( / )
   (alert s)
« Reply #7 on: August 03, 2007, 03:14:24 PM »
Try this at the command line:
!T
If it returns nil, then you have redefined T somewhere in some code .. I had a novice programmer do that some years ago and it took me a while to figure it out.
A_LOTA_NOTA
« Reply #8 on: August 03, 2007, 03:19:04 PM »
No it doesn't...
   (alert s)
[/quote]
If I put a leading space then a letter ("  A9513C A") it works fine. But if I do a space then a number ("  9513C A") it doesn't work.
Guest
« Reply #9 on: August 03, 2007, 03:21:42 PM »
First it was a leading space.
Now it's a leading space AND then an integer.
Either way, it still works.
« Reply #10 on: August 03, 2007, 03:24:29 PM »
I don't know why it doesn't work for you, but it works for me.  Here is a copy from the command line.
Command: (getstring T "\n Testing: ")
 Testing:  567
" 567"
 Testing:  happy
" happy"
You can see that both have a leading space.
A_LOTA_NOTA
« Reply #11 on: August 03, 2007, 03:28:42 PM »
Well I didn't know about the integer until doing some tests. Guess it is just my machine! Thanks for the help.
A_LOTA_NOTA
« Reply #12 on: August 03, 2007, 03:33:57 PM »
 Testing:  567
" 567"
 Testing:  happy
" happy"
If I type this at the command prompt as you have done I get the same result as you. But if I run example posted by Matt. This is what I get.
Command: !S
CADaver
« Reply #13 on: August 03, 2007, 03:40:59 PM »
 Testing:  567
" 567"
 Testing:  happy
" happy"
Command: !S
Texteval??  Nah, works for me either way.
« Last Edit: August 03, 2007, 03:43:28 PM by CADaver »
« Reply #14 on: August 03, 2007, 03:42:44 PM »
What happens if you press !T at the command line?
I suspect you are not doing something correctly as AutoCAD always interprets the space as a string if you are using the T in the getstring command.
It works perfectly for me here ... perhaps you are making your variable S local to some code ... it is really hard to guess what could be wrong without a little help from you, other than "it don't work". ... maybe a copyclip from the command line, the code you are trying to put it in, a screen shot, something ... anything ... will be better than nothing.
