Author Topic: wood materials  (Read 11259 times)
Barry Clark
Re: wood materials
« Reply #15 on: August 13, 2007, 03:57:24 PM »
AH! Thanks much!
If any one can tell me why I am not able to rotate the appearance of the grain, I would greatly appreciate it!
Josh Nieman
Re: wood materials
« Reply #16 on: August 13, 2007, 04:13:45 PM »
AH! Thanks much!
I think this is how you're looking to have it?
Barry Clark
Re: wood materials
« Reply #17 on: August 13, 2007, 04:31:48 PM »
When I render it, the grain is still running 90 degrees off of where I want it. I need the grain to run lengthwise in the render.
Josh Nieman
Re: wood materials
« Reply #18 on: August 13, 2007, 04:41:12 PM »
err.. wierd, let me check the file, I'm pretty sure I saved before I uploaded it, but I may have forgotten to save before attaching it to the post  :laugh:
Josh Nieman
Re: wood materials
« Reply #19 on: August 13, 2007, 04:42:22 PM »
Like this?
This is how the file looks to me.  What version of Autocad are you using again?
Barry Clark
Re: wood materials
« Reply #20 on: August 13, 2007, 04:47:58 PM »
When I got it, it came in as a sort of peach colored solid.
I am using ACAD 2007.
Barry Clark
Re: wood materials
« Reply #21 on: August 13, 2007, 04:53:52 PM »
This is how it comes up for me when I render it.
Josh Nieman
Re: wood materials
« Reply #22 on: August 13, 2007, 05:09:59 PM »
Sorry, I forgot just how DRASTIC the rendering/material handling changes were between 07 and 08... I opened it up in 2007 instead of 2008 this time and made the alterations.  I think something was lost in translation.
I got it to work in 08, but sorry, pal, 07 seems to not want to rotate anything, or supply any means of doing so.  I've never used the standard wood/marble materials though, whenever I had wood materials, I used the standard diffuse map and bump map methods and simply chose wood images for the maps.
