Author Topic: (Microstation) Patterning/Filling  (Read 2104 times)
billabong
« on: July 31, 2007, 06:28:04 AM »
There could be a particularly easy fix for this and MS is just bugging me for no reason (surprise surprise)
But I cant solid hatch a selected area.....Does MS have this function?? hatch, crosshatch...but no solid.  :pissed:
jonesy
  • SuperMod
Re: Patterning/Filling
« Reply #1 on: July 31, 2007, 06:38:38 AM »
MS does have this ability :-)
You'll need to set the filltype to solid via the change attributes (see piccy below)
Hope this helps :-)
billabong
« Reply #2 on: July 31, 2007, 06:42:49 AM »
Yeah for elements thats perfect, but I'm trying to hatch an area (namely a lane of a road)
So I need to pick a point inside, it will find the area and flood it with solid.
Arizona
« Reply #3 on: July 31, 2007, 07:06:04 AM »
Try this...
billabong
« Reply #4 on: July 31, 2007, 07:06:42 AM »
Hope this helps :-)
This did work, I had to define the region first and then use the active fill type command.
Cheers
