Author Topic: Xref path: relative path question  (Read 1782 times)
Dream.Fei
« on: July 31, 2007, 12:38:29 AM »
Used "vla-attachexternalreference" method to attach a dwg as xref
question is : how can I put the xref's path to "Relative path" not "Full path".
Sos
Re: Xref path: relative path question
« Reply #1 on: July 31, 2007, 09:05:24 AM »
My company has its directory structure and you have yours.
...Your not giving us enough information.
Dream.Fei
« Reply #2 on: August 02, 2007, 07:40:09 AM »
How no matter the way, all does need to preserve into the relativeway.
Perhaps is from the local hard disk, also has the possibility isthe local area network.
We suppose have a fixed folder "D:\Working File\Project Files\Project Name" ,all documents all are under this folder ,Refers to the folder is fixed "D:\Working File\Project Files\Project Name\Xref" , But other documents are not fixed, moreover has how many folder not tobe indefinite .
My question is: How can let under this project folder all quotationsreference all preserve the relative way
   Please note: Is inserts exterior reference by "vla-attachexternalreference" not command。
« Last Edit: August 02, 2007, 07:52:18 AM by Dream.Fei »
