Author Topic: dual sized double swing  (Read 7407 times)
ryandk
« on: July 09, 2004, 03:04:26 PM »
Does anybody here know how, if at all possible, to make a double door have two different sizes (ie. whole doorway=5' with left door=2' and right door=3')?
I can't quite figure it out.  I've even given thought to making a window assembly that would act as one but there would be a frame between them and that's no good.
Thanks,
Ryan
42
« Reply #1 on: July 09, 2004, 04:01:40 PM »
In ADT 3.0 and 3.3 choose door styles, under design rules there is a menu with a variety of options, there you will see uneven and uneven double hung and uneven opposing. Choose your style. Go to Standard sizes insert the overall door size, the leaf size is the smaller leaf.
Alastair
Alastair Mallett Autodesk Certified Professional
Technical Director
Hunters South Architects
ryandk
« Reply #2 on: July 09, 2004, 06:41:14 PM »
Thank you very much.  The uneven was exactly what I needed.  I had no idea what a door such as that would have been called.  Thanks for the lesson.
42
« Reply #3 on: July 10, 2004, 06:11:26 AM »
Glad to help
Alastair
 8)
Technical Director
