Author Topic: Move dims and text to dim layer  (Read 3107 times)
Biscuits
« on: July 27, 2007, 11:05:22 AM »
Using Acad2008 on XP
Anyone have a routine that would move all existing dims and text within a drawing to "dim" layer?
I work with an engineer who likes to draw everything on one layer.......argh!
Guess it could be worse!
M-dub
Re: Move dims and text to dim layer
« Reply #1 on: July 27, 2007, 11:07:13 AM »
Just a stab in the dark, but could you use the command, 'Qselect' to select said objects and change them manually?
« Reply #2 on: July 27, 2007, 11:10:08 AM »
Something like
(vlax-for lo (vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object)))
 (vlax-for obj (vla-get-Block lo)
   (or
    (vl-position (vla-get-ObjectName obj) '("AcDbText" "AcDbMText"))
    (vl-string-search "Dimension" (vla-get-ObjectName obj))
   (vla-put-Layer obj "Dim")
Edit: Forgot a paren.
« Last Edit: July 27, 2007, 02:32:20 PM by T.Willey »
« Reply #3 on: July 27, 2007, 12:05:47 PM »
optionally
click on the offending item(S)>>then right-click and chose Select Similar
then use the Layer Pull down on standard menu to move them to the correct layer,
or use the properties box to do same
Fatty
« Reply #4 on: July 27, 2007, 01:02:57 PM »
I use similar on following one,
where command is accordingly layer
name on wich you want to offset the objects
I mean:
OF - offset
Dim - layer name
Easier to remember for me...
Hth
(defun C:OFDim (/)
(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
(command "._-layer" "m" "dim" "c" "7" "dim" "")
(vlax-for layts (vla-get-layouts
 (vlax-for obj (vla-get-block layts
  (if (wcmatch (vla-get-objectName obj) "*Text,*MText,*Dimension")
(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
(princ "\n   >>> Type OFDIM to execute...")
~'J'~
GDF
« Reply #5 on: July 27, 2007, 02:13:51 PM »
Tim and Fatty
I get the following:
; error: bad argument type: VLA-OBJECT nil
Gary
« Reply #6 on: July 27, 2007, 02:33:08 PM »
Tim and Fatty
Gary
It worked for me, once I put in the paren I forgot (updated code in first post).  I wonder if the layer is locked if you would get that message?
GDF
« Reply #7 on: July 27, 2007, 03:47:24 PM »
Strange, it's working now, and I did what you did.
Gary
« Reply #8 on: July 27, 2007, 04:19:44 PM »
Gary
That is strange.  I have no idea why you would get that error, as there is no way to not get a vla-object in that code, when it is looking for one, at least that I can see.   :ugly:  If I'm wrong, please show me.  :-)
Biscuits
« Reply #9 on: July 30, 2007, 11:53:09 AM »
Thanks for all the help
I came up with this all by my lonesome
Nuthin purty..but it workt
(defun c:KLEINLAYER ()
 (command "-layer" "T" "*" "U" "*" "ON" "*" "")
 (command "-layer" "m" "CENTER" "c" "GREEN" "" "ltype" "CENTER2" "" "")
 (command "-layer" "m" "DWG" "c" "CYAN" "" "ltype" "CONTINUOUS" "" "")
 (command "-layer" "m" "SECTION" "c" "230" "" "ltype" "PHANTOM" "" "")
 (command "-layer" "m" "DIM" "c" "RED" "" "ltype" "CONTINUOUS" "" "")
 (command "-layer" "m" "HIDDEN" "c" "YELLOW" "" "ltype" "HIDDEN" "" "")
 (command "-layer" "m" "CORE" "c" "255" "" "ltype" "CONTINUOUS" "" "")
 (command "-layer" "S" "DWG" "")
(setq DIMset (ssget "X" '((0 . "DIMENSION"))))
(setq TEXTset (ssget "X" '((0 . "TEXT"))))
(setq MTEXTset (ssget "X" '((0 . "MTEXT"))))
(command ".chprop" DIMset "" "LA" "dim" "")
(command ".chprop" TEXTset "" "LA" "dim" "")
(command ".chprop" MTEXTset "" "LA" "dim" "")
(PRINC)
