Author Topic: Cadís uI MFC Classes.  (Read 5983 times)
MickD
  • (x-in)->[process]->(y-out)
Re: Cadís uI MFC Classes.
« Reply #15 on: July 25, 2007, 08:59:12 PM »
Yes Thanks... Thanks for the info on MFC - I'll stick with it.
No prob's, if your goal is only to customise autocad then that's probably a good idea and you will be able to keep up with later features your end user would expect as they're introduced, I just like win32 as I can take my resource script/hand coding with me to other app's with little if any modification.
Lao Tzu: ďTo attain knowledge, add things
every day; to obtain wisdom, remove things every day.Ē
