Author Topic: remove major stations  (Read 3561 times)
« on: July 24, 2007, 02:14:19 PM »
Is it possible, and if so how, to remove the "Major" stations at the beginning and end of a "Alignment"?
thanks
Dinosaur
Re: remove major stations
« Reply #1 on: July 24, 2007, 02:21:50 PM »
I have been selecting each and check visibility to "off" in the label properties dialog - very tedious.
« Reply #2 on: July 24, 2007, 02:49:29 PM »
How about a screen shot 'cause I don't see it.
Dinosaur
« Reply #3 on: July 24, 2007, 03:00:35 PM »
This help?
« Reply #4 on: July 24, 2007, 03:23:52 PM »
This help?
No but the following did the job. Thanks Dino
Lin-Z
« Reply #5 on: July 24, 2007, 03:25:46 PM »
You could try changing the beginning and ending station for major labels on the Alignment Properties Labels tab.  Uncheck the Start Station and End Station boxes and enter the next one over.  Then you don't have to keep changing visibility states and if you ever need it back you just check the box.
Screen shots arn't possible right now, so if anyone knows what I mean, can you please post it?  Thanks
Edit: OK, I'm severely slow today.  Glad it all worked out  :-)
Dinosaur
« Reply #6 on: July 24, 2007, 03:27:23 PM »
OK, you wanted all of them gone.  I thought you wanted to just lose the offending ones.  If this is a common condition you want to show you should probably make a style for it.
« Reply #7 on: July 24, 2007, 03:41:12 PM »
No just the beginning and ending stations. The "Profile Geometry Point" also has the station, I didn't need it labeled twice.
« Reply #8 on: July 24, 2007, 04:24:22 PM »
assign a no label style to those geometry points...
OK that didn't works as expected.....send me an email and I will forward a DWT containing a proper sample to you.
« Last Edit: July 24, 2007, 04:27:51 PM by mjfarrell »
