Author Topic: AutoLISP Resource Request : List of functions and summary  (Read 8708 times)
Josh Nieman
« on: July 23, 2007, 10:28:36 AM »
Does anyone know of anywhere I can find a list of all autolisp functions and summary or definition of their use, hopefully all on one page, no matter how gigantic...
I'm wanting something searchable.  I've found a couple resources that list all the autolisp functions, but it'll be like a list of links on one page, and the definitions on the next sheet.
This is HORRIBLY backwards logic for someone trying to learn how to write their first complex routine.  I know what I want to do, and how to do it, I just don't know the proper function names or formatting.  If I knew the proper name, I wouldn't need the resource, now would I?
So I was hoping there would just be a massive list somewhere with the explanation on the same page, so I could just (ctrl+f) a few key words about what I'm trying to do, and sift through the results and find the function I need.
Am I barking up a wrong tree, here?  I couldn't find anything in the Autocad help, nor google.
Re: AutoLISP Resource Request : List of functions and summary
« Reply #1 on: July 23, 2007, 10:41:45 AM »
{ thinking out loud }
Some ambitious copying / pasting and you could make you own custom reference from the AutoLISP Reference that ships with AutoCAD.
A utility that would make that task easier is ClipMate (I use said utility a lot).
Another might be to use Adobe Acrobat (and equivalents) to print the contents to one one file.
{ / thinking out loud }
Josh Nieman
« Reply #2 on: July 23, 2007, 10:44:29 AM »
aaaaaaawha??
*starts searching through files*
Krushert
  • FREE BEER Tomorrow!!
« Reply #3 on: July 23, 2007, 11:06:27 AM »
I will take a copy of what ever you come up with and I will buy the beer, If I ever get down your way.  I am in the same boat as you.
« Reply #4 on: July 23, 2007, 11:10:48 AM »
<AutoCAD Install Folder>\Help\acad_alr.chm
Edit: You might also be interested in --
<AutoCAD Install Folder>\Help\acad_alt.chm
« Last Edit: July 23, 2007, 11:12:30 AM by MP »
Josh Nieman
« Reply #5 on: July 23, 2007, 11:36:29 AM »
w00t
Yes, that'll be a bit of copy/pasting, but not bad at all!!
I'll probably put together a little LSP reference WORD document with a link to the file.
..actually... scratch that... if you paste into MS Word... it automatically creates the hyperlinks to each bookmark in the file...
sweeeeeeeeet
thanks be to EM-PEE!!
I never knew of, or saw reference to, these files!  Nor would I have known of them by their file name... because I had looked through the Autocad folders out of curiosity for anything with a name that looked like it might be lisp-related...
« Last Edit: July 23, 2007, 11:37:53 AM by Josh Nieman »
Josh Nieman
« Reply #6 on: July 23, 2007, 11:48:12 AM »
If anyone cares, this is just a .doc off each alphabetical page from the .chm file.
It may just make things easier, I dunno.  I think I'm going to probably just be using the search function within the .chm file.
Guest
« Reply #7 on: July 23, 2007, 12:03:19 PM »
Your lack of page breaks disappoints me.  :-( :wink:
Josh Nieman
« Reply #8 on: July 23, 2007, 12:29:15 PM »
yea I didn't waste my time with formatting since I wasn't going to use it.  I figured if someone else wanted to use it, they could apply their own special format.  Since the goal was simply to have a conglomerated mass of text that was CTRL-F'able (hehe F'able) then formatting wasn't important, since it won't be read in it's entirety, nor printed, but rather read one entity at a time (which I did make sure that a function and it's description was NOT split over a page break)
So nyah.
  • Custom Title
« Reply #9 on: July 24, 2007, 08:52:22 AM »
Here's one I made for Vim.
jbuzbee
« Reply #10 on: July 24, 2007, 09:38:23 AM »
I didn't see this mentioned but I'm assuming you've typed VLIDE at the command prompt?
James Buzbee
Windows 8
« Reply #11 on: July 24, 2007, 11:37:24 AM »
My favorite! (I use that one constantly!)
Josh Nieman
« Reply #12 on: July 24, 2007, 11:49:12 AM »
I was messing around in that thing and I can't say that I'm all that comfortable using it yet.
Every bit of coding/writing I've ever done, I've always been more comfortable with using notepad.
When I was into skinning applications graphically, adding any type of additional functions, I wanted pure, stripped down notepad.
When I was into HTML/CSS when I was dabbling with website design, I wanted stripped down notepad.
I feel more comfortable with the raw language there without all the extras, doodads, and complications.
When I'm more comfortable with the Autolisp language, I may jump ships to using that editor, but while I'm just learning to get comfortable with the language, I'd prefer stripped naked notepad.
Thanks so much, Mark!
I think I'm actually going to use this instead!  Very thorough and quite a bit more information.
Guest
« Reply #13 on: July 24, 2007, 11:49:20 AM »
*Tsk* *Tsk* *Tsk* Never ass-u-me.
Maverick®
« Reply #14 on: July 24, 2007, 11:53:11 AM »
...... I've always been more comfortable with using notepad.
....... I wanted stripped down notepad.
...... I'd prefer stripped naked notepad.
Fickle Wench, aintcha?
