Author Topic: How to find out where Acad reads font files from?  (Read 12530 times)
« on: July 20, 2007, 02:49:23 PM »
I want to be able to populate a list box in a dcl with all the font's that show up when a user is in the styles command.  I'm trying to improve one of my routines that I just did to merge text styles.  I want to be able to create text styles from the dialog, but I don't see where one can find out where Acad reads it's font files from.
One thought was looking at all paths within the preferences, and searching for anything that has the extension of a font file, but I don't see how it knows where to find the true type (window) fonts.
Thanks in advance.
Guest
Re: How to find out where Acad reads font files from?
« Reply #1 on: July 20, 2007, 02:56:09 PM »
C:\Windows\Fonts is the only location a TTF can be installed as far as I know.
« Reply #2 on: July 20, 2007, 02:59:31 PM »
Thanks Matt.  Didn't know that.
Guest
« Reply #3 on: July 20, 2007, 03:01:19 PM »
You're welcome!
CaddmannQ
« Reply #4 on: July 20, 2007, 08:39:17 PM »
This is because C:/windows/fonts is not a folder. It's a program that just looks like a folder. It serves the fonts up to the O/S when they're called for without the fonts having to reside in memory. (I believe. Windows gurus please correct me if I'm wrong here)
To see this just copy a true type font from Fonts to any other location, and the name will change. What you now see is the true file name. What you see in the Fonts folder is what the font tells the program to display as the name.
Outside of the Fonts folder it cannot do so.
For instance the font Impress BT will display the actual name TT0209M_.TTF once you copy it out of the Fonts folder.
« Reply #5 on: July 20, 2007, 08:53:20 PM »
Tim, Does the Fonts Folder in the Acad folder help ?
Personally, I cheat ...
CaddmannQ
« Reply #6 on: July 20, 2007, 09:23:37 PM »
AFAICT it's got to be in the Windows fonts folder. Putting it in the Autocad fonts folder won't do it.
« Reply #7 on: July 20, 2007, 09:59:02 PM »
If I pretend to know what you're looking for perhaps this --
(defun _GetSpecialFolder ( name / wshShell specialFolders result )
    (vl-catch-all-apply
       '(lambda (  )
            (setq
                wshShell       (vlax-create-object "WScript.Shell")
                specialFolders (vlax-get wshShell 'SpecialFolders)
                result         (vlax-invoke specialFolders 'Item name)
    (if specialFolders (vlax-release-object specialFolders))
    (if wshShell (vlax-release-object wshShell))
    result
(_GetSpecialFolder "fonts")
=> "C:\\Windows\\Fonts"
Is that what you're looking for Tim?
« Reply #8 on: July 21, 2007, 12:09:25 AM »
In case anyone is curious about other 'special folders' that are available --
(defun _GetSpecialFolders ( / wshShell specialFolders result )
    (vl-catch-all-apply
       '(lambda ( )
            (setq
            (setq result
                (mapcar
                   '(lambda ( name )
                        (list
                            name
                        "AllUsersDesktop"
                        "AllUsersStartMenu"
                        "AllUsersPrograms"
                        "AllUsersStartup"
                        "Desktop"
                        "Favorites"
                        "Fonts"
                        "MyDocuments"
                        "NetHood"
                        "PrintHood"
                        "Programs"
                        "Recent"
                        "SendTo"
                        "StartMenu"
                        "Startup"
                        "Templates"
    result
(GetSpecialFolders) <Vista Ultra> ...
("AllUsersDesktop"   "C:\\Users\\Public\\Desktop")
("AllUsersStartMenu" "C:\\ProgramData\\Microsoft\\Windows\\Start Menu")
("AllUsersPrograms"  "C:\\ProgramData\\Microsoft\\Windows\\Start Menu\\Programs")
("AllUsersStartup"   "C:\\ProgramData\\Microsoft\\Windows\\Start Menu\\Programs\\Startup")
("Desktop"           "C:\\Users\\UserName\\Desktop")
("Favorites"         "C:\\Users\\UserName\\Favorites")
("Fonts"             "C:\\Windows\\Fonts")
("MyDocuments"       "C:\\Users\\UserName\\Documents")
("NetHood"           "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Network Shortcuts")
("PrintHood"         "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Printer Shortcuts")
("Programs"          "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs")
("Recent"            "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Recent")
("SendTo"            "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\SendTo")
("StartMenu"         "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu")
("Startup"           "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\Startup")
("Templates"         "C:\\Users\\UserName\\AppData\\Roaming\\Microsoft\\Windows\\Templates")
If you want additional info ... looky. There are typos on the linked page, can you find them?
/Later dudes.
« Last Edit: July 21, 2007, 12:27:05 AM by MP »
« Reply #9 on: July 21, 2007, 03:03:10 AM »
Thanks guys.  I will look into this more on monday when I'm not busy, and have Acad with me.  This is how I did it in my code for now.
(foreach path (cons "C:\\Windows\\Fonts" (StrParse (getenv "ACAD") ";"))
 (foreach font (append (vl-directory-files path "*.shx" 1) (vl-directory-files path "**.ttf" 1))
  (if (not (assoc font FontList))
   (setq FontList (cons (cons font path) FontList))
I think I like the way Michael did it with the special folder, and looking for the font within them.  I like that way as it is not hard coded anywhere.
It didn't look like any true type fonts were within those folders.  I could have be wrong.  Maybe on others computers there are in there, but mine didn't seem to have any.
« Reply #10 on: July 23, 2007, 11:41:35 AM »
Thanks again Michael.  This seems to be the best way to do what I want.
« Reply #11 on: July 23, 2007, 11:47:35 AM »
My pleasure Tim, thanks.
« Reply #12 on: July 23, 2007, 03:01:57 PM »
 There should be a way to retrieve the font name along with the file name like you see when using the file browser & viewing the Font Folder.  Because you cant tell fron the file name the actual Font Name.
« Reply #13 on: July 23, 2007, 03:20:13 PM »
The windows font folder is simply another folder, just like all other folders. The only difference is the context handler is different for that specific folder.
By looking into the directory from the command window you will see the fonts are listed just like any other file. The long names you see are the names defined in the font file as retrieved by the context handler.
Every "special" folder has a context handler and you can remove that context handler if you wish, but it is not advisable as system instability can occur.
CaddmannQ
« Reply #14 on: July 23, 2007, 04:34:13 PM »
OK, that seems a little clearer. So I take it that these "context handlers" are programs called by a folder based on some properties given it? In any event, when you click a typical folder, you are activating the default behavior of Explorer, because it has the "default" context handler assigned to it? When you dump a new TTF into the Fonts folder, it's this context handler that "installs" it as an available font?
