Author Topic: Select Multiple Files  (Read 7568 times)
Re: Select Multiple Files
« Reply #15 on: July 18, 2007, 03:13:17 PM »
Nice! Screen shot please. :-)
AutoCAD 2008 / OpenDCL 4.0 RC3 / Vista Ultra / Medium icon mode.
{  reduced colors to 256 after screen grab, it looks richer than this actually }
« Reply #16 on: July 18, 2007, 03:36:04 PM »
Another piccy, same specs as before except detail view with multiple files selected ...
LE
« Reply #17 on: July 18, 2007, 06:41:38 PM »
About half our staff is still running R2002
I have not read anywhere if it is going to be available for pre - 2004 AutoCAD versions.... maybe it will - the arx binaries I have seen are for 2004-2008
CADaver
« Reply #18 on: July 18, 2007, 06:59:27 PM »
By the end of the year we hope to be fully embedded with R2008
LE
« Reply #19 on: July 18, 2007, 07:07:37 PM »
That it is going to be good! - I just started with a2007 jumping from a2005, have my copy of a2008 and do not know when I am going to start with that....  :-(
Note to the people from OpenDCL... Where is the information about what AutoCAD and verticals products OpenDCL will be supporting? - Thank you - in the mean time I'll go and check their new site.
« Reply #20 on: July 18, 2007, 07:11:58 PM »
http://www.opendcl.com/HelpFiles/main.html
LE
« Reply #21 on: July 18, 2007, 07:13:16 PM »
Perfect! thanks.
