Author Topic: VLAX-OBJECT function not found  (Read 5082 times)
CADaver
« on: July 17, 2007, 03:30:57 PM »
Okay, one of my new guys broke something.  Any function that calls a VLAX function gets an unknown command error when attempting to execute.  All the paths are the same, profiles the same, hardware the same, same, same, same.
Short of complete re-install, where do I look first??
Re: VLAX-OBJECT function not found
« Reply #1 on: July 17, 2007, 03:33:29 PM »
« Reply #2 on: July 17, 2007, 03:36:30 PM »
Subtitle: Did the user implement his own acad.lsp, acaddoc.lsp, acad.mnl etc. and by chance does his version fail to execute a (vl-load-com) in the startup / initiation sequence?
EDit: Wow, fixed up pathetic grammar. Kinda.
« Last Edit: July 17, 2007, 03:38:49 PM by MP »
CADaver
« Reply #3 on: July 17, 2007, 04:07:33 PM »
nah its there too
« Reply #4 on: July 17, 2007, 04:10:03 PM »
What happens on his machine when you execute that statement?
Also, check his acadprefix contents, how does it compare to other functioning machines?
    (princ (getvar "acadprefix"))
Any other telling messages on startup?
CADaver
« Reply #5 on: July 17, 2007, 04:11:36 PM »
Nope all the same.  I'm beginning to think he deleted something and tried to copy it off another machine, but he's not 'fessing up to anything.  There are a couple of oddities about his directories.  Basically he's gotten "the look" and the "the growl".  I think we'll just re-install tonight.  Thanks for the help.
CADaver
« Reply #6 on: July 17, 2007, 04:16:46 PM »
hmmm... I'll check as soon as it quits raining, I looked earlier and nothing jumped out, but I'll check again..
CADaver
« Reply #7 on: July 17, 2007, 06:03:44 PM »
No joy there either "Acadprefix" is the same and (vl-load-com) shows no errors. It may be time for "web watcher".
LE
« Reply #8 on: July 17, 2007, 06:11:18 PM »
Randy;
So there is nothing on the command prompt?
Command: (setq str "test")
"test"
Command: !str
"test"
Command !.
error: misplaced dot on input
CADaver
« Reply #9 on: July 17, 2007, 07:32:16 PM »
Everything works as it should EXCEPT anything from Visual Lisp.  Anything with VLA or VLAX in the function returns an error. Regular lisp functions work just fine, as do most of the expresstools I've tried.  Curiouser and curiouser...
« Reply #10 on: July 17, 2007, 07:56:11 PM »
Does the editor work ? ie
VLIDE at the command line.
Which ACAD version ?
Is the VL.ARX file loaded ?
piccy ..
CADaver
« Reply #11 on: July 17, 2007, 09:11:16 PM »
R2002 in this case.  Yes VL.ARX is loaded, nope VLIDE doesn't work, it seems to try.  A window blinks then goes away, no error message though.  Oddity upon oddity??
« Reply #12 on: July 17, 2007, 09:43:58 PM »
Hmmm ... what happens when you try to load up the vba editor (vbaide)? Does it load up? If so, will the visual lisp editor load up after that (vlide)?
Didge
« Reply #13 on: July 18, 2007, 04:29:23 AM »
This sounds very familiar CADaver
http://www.theswamp.org/index.php?topic=17389.0
Although I found a few other cases on the AutoDesk forums I couldn't find any solution, sadly a complete re-install of AutoCAD failed to fix the issue either.  I'll be wathing this thread with interest.
Think Slow......
CADaver
« Reply #14 on: July 18, 2007, 07:57:13 AM »
Yep VBAIDE worked and so do the functions, nope still no vla even after that.
« Last Edit: July 18, 2007, 08:00:13 AM by CADaver »
