Author Topic: select case Angle  (Read 3523 times)
Humbertogo
select case Angle
« on: July 17, 2007, 03:18:05 PM »
i try to make a simple selection of a different angles
but when  dblangle = 135 or 225 nothing is select
 :-D :ugly:
Select Case dblangle
Case 0, 135, 180, 225
David Hall
  • Automatic Duh Generator
Re: select case Angle
« Reply #1 on: July 17, 2007, 03:22:41 PM »
what exactly are you trying to do?
David Hall
« Reply #2 on: July 17, 2007, 03:23:14 PM »
Angles are measured in Radians, so that might be giving you a problem
Humbertogo
« Reply #3 on: July 17, 2007, 03:26:56 PM »
            dblradians = ThisDrawing.Utility.AngleFromXAxis(PolySp, PolyEp)
             dblangle = dblradians * (180 / PI)
                     dblAng = 0 * (PI / 180)
i just try to convert  135, 180, 225 degreed to 0
David Hall
« Reply #4 on: July 17, 2007, 03:29:17 PM »
I dont know if you miss typed, but what is dblAng vs dblangles?  If you wanted to set them all to 0, why not dblAng = 0  ?
Humbertogo
« Reply #5 on: July 17, 2007, 03:32:43 PM »
dblangle = dbl radians* (180 / PI)'conv radians to Degree
dblAng is my return value
Humbertogo
« Reply #6 on: July 17, 2007, 03:34:53 PM »
you right but i can not select 135 and 225
David Hall
« Reply #7 on: July 17, 2007, 03:41:02 PM »
ok, I tried to duplicate your problem, and I think your problem is the decimal point.
Option Explicit
Sub Example_AngleFromXAxis()
    ' This example finds the angle, in radians, between the X axis
    ' and a line defined by two points.
    Dim pt1(0 To 2) As Double
    Dim pt2(0 To 2) As Double
    Dim retAngle As Double
    pt1(0) = 2: pt1(1) = 5: pt1(2) = 0
    pt2(0) = 5: pt2(1) = 2: pt2(2) = 0
    ' Return the angle
    retAngle = ThisDrawing.Utility.AngleFromXAxis(pt1, pt2)
    retAngle = RtoD(retAngle)'*****   added by cmdrduh
    ' Create the line for a visual reference
    Dim intretangle As Integer
    intretangle = CInt(retAngle)
    Select Case intretangle
    Case 0
    MsgBox "0"
    Case 315
    MsgBox "315"
    End Select
' end of  *****   added by cmdrduh
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
    ZoomAll
    ' Display the angle found
    MsgBox "The angle in radians between the X axis and the line is " & retAngle, , "AngleFromXAxis Example"
End Sub
Private Function DtoR(d As Double)      ' Degrees to Radians
      Const PI = 3.14159265
      DtoR = (PI * d) / 180
End Function
Private Function RtoD(r As Double)      ' Radians to Degrees
      RtoD = (180 * r) / PI
End Function
this function came out of help, and I added the select case part.  I could not get it to find the 315 degree line, til I used CInt() to convert the double to and integer.  You could probably do something similiar, or broaden your select case
« Last Edit: July 17, 2007, 03:44:17 PM by CmdrDuh »
Humbertogo
« Reply #8 on: July 17, 2007, 03:57:47 PM »
David Hall
« Reply #9 on: July 17, 2007, 04:16:45 PM »
there is probably a much better way to do that, but Im too tired right now to think.  Maybe a guru can lend a hand here.
DaveW
« Reply #10 on: July 17, 2007, 10:20:07 PM »
Try using round of the returned angle value.
MyValue = MyReturnedAngle
MyValue = Round(MyValie, 3) will put you are 3 decimals. Adjust your case accordingly.
Bryco
« Reply #11 on: July 17, 2007, 11:29:59 PM »
Definately a rounding problem, although below works I would rather set the angle first
Select Case dblAngle
Case -0.00001 To 0.000001, 134.99999 To 135.0001, 179.00001 To 180.00001, 224.99999 To 225.000001
    Debug.Print dblAngle
End Select
David Hall
« Reply #12 on: July 18, 2007, 10:39:29 AM »
I used both of these to test that theory.  I like the Round better.
retAngle = Round(retAngle, 0)
retAngle = retAngle \ 1
the first rounded with no decimal places, (duh)
but the second one I used Integer Division, which would drop the decimal place as part of the division
Humbertogo
« Reply #13 on: July 19, 2007, 03:54:57 AM »
                retAngle = ThisDrawing.Utility.AngleFromXAxis(PolySp, PolyEp)
              'uses the Mod operator to divide two numbers and return only the remainder.
               intretangle = intretangle Mod 90
