Author Topic: point filter routine for a 3dpoly  (Read 2486 times)
wjbzone
« on: July 17, 2007, 08:06:10 AM »
I want to draw a 3dpoly line using point filters. Each point of the 3dpoly should osnap to .Z of one object and .XY of another object.
Is there an easy way can I speed this up with autolisp routine?
Or will have to build the 3dpoly point list and use entmake to accomplish. (not easy for me)
Thanks ,
Bill
gile
  • Marseille, France
Re: point filter routine for a 3dpoly
« Reply #1 on: July 17, 2007, 08:40:51 AM »
What kind of objects do you want to use as point filter ?
Can you post an example (dwg) ?
Bred
« Reply #2 on: July 17, 2007, 09:10:18 AM »
Hello,
1-There is to you it a bond between “XY” object and "Z" object?
2-how you select “XY” object and "Z" object?
wjbzone
« Reply #3 on: July 17, 2007, 02:25:33 PM »
I need each point of the 3dpoly to osnap to the .z of endpoint and to the .xy of the current osmode.
There is not a bond between the two objects.
« Last Edit: July 17, 2007, 02:27:03 PM by wjbzone »
gile
  • Marseille, France
« Reply #4 on: July 17, 2007, 02:49:09 PM »
I'm not sure to understand, do you want somethig like this ?
(defun c:3dpoly_filter ()
  (command "_3dpoly")
  (while (/= 0 (getvar "CMDACTIVE"))
    (command ".z" "_end" pause)
wjbzone
« Reply #5 on: July 17, 2007, 03:22:30 PM »
Thanks gile,
That is exactly what I need!
I did not know about the "cmdactive" variable, and that you can use it in a while loop during a active command.  Very good thing. I just added one line for a prompt:
(defun c:3df ()
  (command "_3dpoly")
    (princ "Pick z")
