well using 'list' I find that it's inserted at point, X= 124.3487 Y= 25.9280 Z= 0.0000
Luckily the block creator was wise enough to list the "Gap Dist" in the custom properties of that block, (6.000) and the Overall Length, as well, (79.5142) and thus, using geometry, I figure it'd be easy to figure the coords, since the angle of the line is also included in the custom properties... I'm not 100% sure, but I am guessing... that via lisp, you can extract even the 'custom property' values.... but that's a 100% assumption.
unfortunately, though I may be able (if I was lucky) to assert the path to follow to derive the right answer... I lack the programming skills to translate that into the right language.
