Hello,In lisp, when modify the Adjust Clipping Planes (_3dclip) ?(no entmod...)Thanks.
ThanksExcuse-me but my english is very bad....The dxf code 42 and 43 aren't not modifiable whith entmake or entmode...And I do not have anything to find in vla-object property.How to modify the "Adjust Clipping Planes" in lisp ?thanks.
You cannot use the entmod function to modify a viewport entity.
(defun c:test ()(if (= (getvar "TILEMODE") 1)(princ "\n ** no object space **");Select viewport(progn(if (= (getvar "CVPORT") 1)(progn(while(not (and (setq sel (car (entsel "\n Select viewport :")))(or (equal (cdr (assoc 0 (entget sel))) "VIEWPORT")(equal (cdr (assoc 0 (entget (cdr (assoc 330 (entget sel)))))) "VIEWPORT")))))(setq sel (entget sel)id_fenetre (cdr (assoc 69 sel)))(if (= id_fenetre nil)(progn(setq sel (entget (cdr (assoc 330 sel)))id_fenetre (cdr (assoc 69 sel)))))(command "_.MSPACE")(setvar "CVPORT" id_fenetre)))))(command "_.PSPACE")(setq dxf-AV-43 (cdr (assoc 43 sel)))(setq dxf-AR-44 (cdr (assoc 44 sel)))(setq dec (getreal "shift :"))(setq sel (subst (cons 43 (+ dxf-AV-43 dec)) (assoc 43 sel) sel)sel (subst (cons 44 (+ dxf-AR-44 dec)) (assoc 44 sel) sel))(entmod sel)(princ))
