Author Topic: App Events not working  (Read 18470 times)
Re: App Events not working
« Reply #30 on: July 12, 2007, 11:17:17 AM »
OK, this is a very naive question:
Jeff:
In the exposeappevents module
You have the code
Dim AppEvents As New EventsClass
Sub acadstartup()
Set AppEvents.ACADApp = Application
I understand that you made a new class module but what is actually triggering it (acadstartup)?
THanks
It doesn't need to be triggered, outside of AutoCAD starting up.
ML
« Reply #31 on: July 12, 2007, 11:18:31 AM »
Sorry, I meant to say a new class, not class module.
So you are saying that when ACAD starts, it calls the macro?
ML
« Reply #32 on: July 12, 2007, 11:19:28 AM »
Which then triggers The ACADapp?
« Reply #33 on: July 12, 2007, 01:19:51 PM »
yep
« Reply #34 on: July 12, 2007, 01:57:21 PM »
To expand on Keith's excellent reply :-)
Just as Acad will autoload any acad.lsp, acaddoc.lsp, acad.rx acad.dvb, S::STARTUP (in lisp), and any associated MNL files, it will run an AcadStartup Sub in the now loaded Acad.dvb
ML
« Reply #35 on: July 12, 2007, 02:21:00 PM »
Yeah Keith's explanation was pretty profound
Yep
LOL, I am just kidding Keith. Keith has been a GREAT help to me over the years, I owe him a great bit of gratitude.
Jeff, that was an excellent explanation, thank you
That really clarified a lot for me  :-)
I appreciate all your help!
ML
« Reply #36 on: July 12, 2007, 02:23:48 PM »
Jeff,
You are a Land Desktop user.
With Land Desktop is it still necessary to use the acad.rx file to load the acvba.arx file in order to initialize VBA on startup?
Thank you
« Reply #37 on: July 12, 2007, 02:29:11 PM »
Yep :-)
ML
« Reply #38 on: July 12, 2007, 02:30:58 PM »
Cool!
It looks like we've clarified this "event"  LOL   :-D
Thank you
ML
« Reply #39 on: July 19, 2007, 10:57:42 AM »
Hey Jeff:
Pretty cool,
Branching out on The plot Event that you included
I added some VBScripting Language into The Plot Event
Private Sub ACADApp_BeginPlot(ByVal DrawingName As String)
Dim WshNetwork
Dim username
Set WshNetwork = CreateObject("WScript.Network")
username = WshNetwork.username
MsgBox "Drawing " & DrawingName & "has just received a request to plot for: " & username
ML
« Reply #40 on: July 19, 2007, 11:21:24 AM »
Jeff,
Also I noticed that sometimes when I make changes to the events, I have to re run my ExposeAppEvents (acadstartup) module
Sub acadstartup()
I don't think that should be necessary, do you?
« Reply #41 on: July 19, 2007, 03:34:37 PM »
No, that seems odd. I'm pretty sure that I can make changes and they are immediately used.
ML
« Reply #42 on: July 19, 2007, 03:55:21 PM »
Please
I would appreciate that   :-)
ML
« Reply #43 on: July 24, 2007, 02:13:47 PM »
Oh I'm sorry
I tohught you had a fix
The same situation is still happening???
You would think the event itself would trigger the acadstartup?
Yes, I can have every event handler run acadstartup but this should not be neccessary  :?
So, you have not encountered this problem?
Bryco
« Reply #44 on: July 24, 2007, 03:47:59 PM »
I reset with the AcadDocument_EndCommand "OPEN" and "NEW", notice this is a document level command.
There is also an application level Open and New, but these may not fire.
When you open a new drawing there is a point where thisdrawing changes ownership, this is where the application setting loses it's scope.
