Author Topic: App Events not working  (Read 18677 times)
ML
« on: July 11, 2007, 09:43:30 AM »
I have been having this problem for months but have not followed through with a post to get it resolved:
I have an acad.rx file; in there I tpyed acvba.arx, it looks like it is initializing VBA on startup however I can not get any app events to work
I have the class module created called Class1
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Acad_Application_Events()
    ' This intializes the public variable (ACADApp) which is used
    ' to intercept AcadApplication Events.
    ' The VBA WithEvents statement makes it possible to intercept a generic
    ' object with the events associated with that object.
    ' Before you are able to trigger any of the AcadApplication events,
    ' you first need to run this procedure.
    ' You could get the application from the ThisDocument object, but that
    ' would require having a drawing open, so in this case it is grabbed from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.16.2")
And a module to call it up
Sub ExposeAppEvents()
Dim AppEvents As Class1
Set AppEvents = New Class1
Still nothing
Any suggestions?
Also, does anyone have a fairly simple App Event that I can use a test?
Bryco
Re: App Events not working
« Reply #1 on: July 11, 2007, 10:38:12 AM »
1) Put this at the top of the thisdrawing module (thisdrwawing is a class module)
Private WithEvents AutoCAD As AcadApplication2) Put this in the thisdrawing module as well
Public Sub Acadstartup()
  Set AutoCAD = Application
  AutoCAD.WindowState = acMax
  ThisDrawing.WindowState = acMax
3)In the thisdrawing module of your acad.dvb
Sub ACADStartup()
   Call AcadApplication.RunMacro("F:\Project startup2006.dvb!App_StartMacro")
Place your path to the dvb you are loading.
4)At the top of your vbaide window there are 2 control boxes, the one on the left is called the object box.
It will probably say (General), if you click the arrow and select "AutoCAD", the pull down box on the right ("Procedure")  will have a listing of all the available application level apps.
Click on BeginOpen, and a sub of that name will appear, write MsgBox("opening") in there.
ML
« Reply #2 on: July 11, 2007, 10:45:28 AM »
Bry
I failed to mention that all of the above is in my acad.dvb file
ML
« Reply #3 on: July 11, 2007, 10:48:21 AM »
I could be wrong but it looks like you are grabbing the events from drawing level instead of from The system?
ML
« Reply #4 on: July 11, 2007, 10:49:04 AM »
Which would require a drawing to be open   :-(
Jeff_M
  • C3D user & customizer
« Reply #5 on: July 11, 2007, 11:03:51 AM »
Hi Mark,
Attached is my acad.dvb that uses events. See if it helps what you want to do. This has code in it for LandDesktop specific items, but that part shouldn't run if LDT is not running.
Jeff
ML
« Reply #6 on: July 11, 2007, 11:26:20 AM »
Cool Jeff
How are you calling it up?
THanks
ML
« Reply #7 on: July 11, 2007, 11:46:26 AM »
Jeff
That is good stuff
The cool thing is that I use Land Desktop also but I am still a bit too new at it to really appreciate what you have done. It is certainly worth hanging onto.
In my acad.dvb file
I did a simple event:
Private Sub ACADApp_BeginSave(ByVal Filename As String)
Dim Filename As String
Filename = Test.dwg
MsgBox "Hello"
When I press the save button, should I not at least get a simple message box?
Thank you
Jeff_M
« Reply #8 on: July 11, 2007, 01:55:57 PM »
Hi Mark,
Not sure what's up, but the docs say the the BeginSave & EndSave events use the AcadApp, but the Examples for both use the AcadDocument....this works:
Private Sub ACADDocument_BeginSave(ByVal Filename As String)
'Filename = Test.dwg ''this will error since it's not a string
MsgBox "Hello"
ML
« Reply #9 on: July 11, 2007, 02:03:37 PM »
Well that is easily solved by
Dim Filenname as String
But the problem I am having is not really using document level events, it is using App level events  :-(
ML
« Reply #10 on: July 11, 2007, 03:14:36 PM »
This came right from the help screen:
Private Sub AcadDocument_BeginPlot(ByVal DrawingName As String)
    ' This example intercepts a drawing BeginPlot event.
    ' This event is triggered when a drawing receives a plot request.
    ' To trigger this example event: Plot an open drawing
    ' Use the "DrawingName" variable to determine which drawing is about to plot
    MsgBox "A drawing has just received a request to plot for: " & DrawingName
I literally copied and pasted the code in the event and still nothing   :-(
WHY?????????
Jeff_M
« Reply #11 on: July 11, 2007, 03:32:14 PM »
Actually, FileName is already defined as a string in the arguments section...... the way you put in Test.dwg was not a string. Also, since the filename is supplied by Autocad, I'm not sure you want to be changing it in this event (I haven't tested that, just a thought).
Does anything in your acad.dvb get run? What about if you replace yours with mine (rename yours, place mine in the support path & restart acad)?
The Plot code works for me......when you start Acad, once it's fully loaded type VBAIDE. Is the acad.dvb there in the editor? If not, it's not loading...... if it is, could you post or email the dvb to me? miff AT sonic DOT net
ML
« Reply #12 on: July 11, 2007, 03:49:38 PM »
Jeff
Mine is loading fine and all looks well but nothing is triggering?  :-(
If you can take a look, I would really appreciate it
DAM, hell do I attach file?
ML
« Reply #13 on: July 11, 2007, 03:50:29 PM »
Ok, it is attached to the last post
Thanks Jeff!
Jeff_M
« Reply #14 on: July 11, 2007, 05:22:28 PM »
One last question, Mark. What Acad version are you using?
