Author Topic: Duplicate Reactors....Arghhhh!!!  (Read 2329 times)
Ron Heigh
« on: July 06, 2004, 10:24:12 AM »
Is there a function to ensure that a reactor isn't duplicated for a entity?
SpeedCAD
Re: Duplicate Reactors....Arghhhh!!!
« Reply #1 on: July 06, 2004, 11:37:13 AM »
Quote from: Ron Heigh
Hi...
Prove this:
(defun scad-vlr-tiene-reactor (vla-objeto / reactores)
  (if (/= (type vla-objeto) 'vla-object)
    (setq vla-objeto (vlax-ename->vla-object vla-objeto))
  (if (setq reactores
    (mapcar 'cadr (vlr-reactors :vlr-object-reactor))
    (apply 'or
  (mapcar '(lambda (x)
     (if (member vla-objeto (vlr-owners x))
t
   ) ;_lambda
  reactores
  ) ;_mapcar
    ) ;_apply
  ) ;_if
) ;_defun
Use:
(scad-vlr-tiene-reactor objeto)
objeto can it a ename or vla-object, example:
Use:
(scad-vlr-tiene-reactor (car (entsel)))
or:
(scad-vlr-tiene-reactor (vlax-ename->vla-object (car (entsel))))
return T or nil
Ron Heigh
« Reply #2 on: July 09, 2004, 05:44:56 PM »
I tried what you posted, but couldn't get it to work.
I'm getting my reactors firing multiple times on the same object.
Some are duplicate persistant reactors as well.
