Author Topic: AutoCAD 2007 Error  (Read 4111 times)
crrussell3
AutoCAD 2007 Error
« on: June 29, 2007, 04:46:32 PM »
While trying to setup Corporate Standard Profiles, I am encountering an error.
Profile setup:
Main Customization File: Custom.cui
Partial Cui File: Acad.cui, Express.cui, and HUSS_REFG.cui, HUSS_MAIN.cui, HUSS_HVAC.cui
The problem is, I am beginning the setup of the profile. I will load the Custom.cui as the MCF, then proceed to load the Acad.cui file. Everything works fine. I can load any combination of the HUSS partials, and everything is fine. As soon as I load in the Express.cui file, I start to have issues. Everything appears to be fine, until I go into the CUI Editor. Once in there, I can't do anything.
Whenever I click on a Toolbar, I get the following Error:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '232' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ImageList.ImageCollection.get_Item(Int32 index)
at Autodesk.AutoCAD.Customization.BitmapCache.GetImage(String resourceId, Boolean small, Boolean return_null)
at Autodesk.AutoCAD.Customization.BitmapCache.GetImage(String resourceIdSmall, String resourceIdLarge, Boolean small)
at Autodesk.AutoCAD.Customization.MainForm.getStandaloneOrCustomResourceDllBitmap( CUITreeNode node, String smallImageName, String largeImageName)
at Autodesk.AutoCAD.Customization.MainForm.populateToolbarPreview(Toolbar toolbar, CUITreeNode node)
at Autodesk.AutoCAD.Customization.MainForm.CustPage_TreeViewControl_ItemSelected(O bject sender, TVCItemSelectedArgs e)
at Autodesk.AutoCAD.Customization.TreeViewControl.FireSelectedItemEvent(TVCItemSel ectedArgs arg)
at Autodesk.AutoCAD.Customization.MultiSelectTreeview.FireSelectedItemEvent()
at Autodesk.AutoCAD.Customization.MultiSelectTreeview.SelectNode(TreeNode node, Boolean fireEvent)
at Autodesk.AutoCAD.Customization.MultiSelectTreeview.OnStartSelect(TreeNode node)
at Autodesk.AutoCAD.Customization.MultiSelectTreeview.OnBeforeSelect(TreeViewCance lEventArgs e)
at System.Windows.Forms.TreeView.TvnSelecting(NMTREEVIEW* nmtv)
at System.Windows.Forms.TreeView.WmNotify(Message& m)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at Autodesk.AutoCAD.Customization.MultiSelectTreeview.WndProc(Message& message)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 17.0.209.0
Win32 Version: 17.0.209.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcdbMgd.DLL
msvcm80
Assembly Version: 8.0.50727.163
Win32 Version: 8.00.50727.163
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.163 _x-ww_681e29fb/msvcm80.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dl l
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/Syste m.Xml.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/S ystem.Drawing.dll
System.Windows. Forms
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934 e089/System.Windows.Forms.dll
acm gd
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/acmgd.DLL
AcDxUi
Assembly Version: 17.0.54.0
Win32 Version: 17.0.54.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcDxUi.DLL
AcDx
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcDx.DLL
AcDxUi.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/en-US/AcDxUi.resources.DLL
AcMgdShared
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcMgdShared.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/en-US/AcLayer.resources.DLL
AcXrefutil
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcXrefutil.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcCustomize.DLL
AcCui
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcCui.DLL
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/Sy stem.Design.dll
acmgdinternal
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/acmgdinternal.DLL
AcMNUParser
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/AcMNUParser.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202007/en-US/AcCustomize.resources.DLL
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d 50a3a/Microsoft.VisualBasic.dll
S ystem.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d5 0a3a/System.Configuration.dll
Sys tem.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System .Data.dll
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
I have also included a screen shot of the error box.
Anyone have any ideas of why the Express.cui file would do this? I have done the following attempts at fixing the error:
1. Reinstalled AutoCAD 2007
2. Installed AutoCAD 2007 Service Pack 2
3. Deleted ALL mnr files
4. Rebuilt the profile more times then I can count
Thanks!
