Author Topic: How do you derturman what type to convert to?  (Read 1690 times)
BazzaCAD
« on: June 22, 2007, 07:43:35 PM »
OK, so I'm reading in a .txt file, and of course everything comes in as a string.
Let's say I have ("abc" "123" "1.5")...
How do I leave the "abc" as a string, convert the "123" to an Int, & convert the "1.5" to a Float?
thx,
Barry
Re: How do you derturman what type to convert to?
« Reply #1 on: June 22, 2007, 07:58:16 PM »
Hi Barry.
perhaps something like ..
(setq
    varlist (list "abc" "123" "1.5")
    newlist '()
(FOREACH var varlist
    (SETQ newlist (CONS (IF (DISTOF var)
                            (READ var)
                            var
                        newlist
(setq newlist (reverse newlist))
« Reply #2 on: June 22, 2007, 08:00:04 PM »
Looking for another thread but found this one.
http://www.theswamp.org/index.php?topic=9780.msg125334#msg125334
BazzaCAD
« Reply #4 on: June 22, 2007, 08:07:08 PM »
thx guys, works great...
