Author Topic: MText Format Stripper  (Read 23222 times)
Shade
« on: June 21, 2007, 11:48:48 AM »
Anyone have a Mtext Format stripper lisp.
I would like the mtext in my drawing to match the the style set in the textstyle, not what is shown in the overrides.
Ie. My text style is Romans; the mtext is set to romans style but shows Arial and 1/2 the size.
I wish to eliminate the 1/2 size and the arial font style from the text.
Any help would be apprecited...
Guest
Re: MText Format Stripper
« Reply #1 on: June 21, 2007, 12:00:47 PM »
Do a search for STRIPMTEXT.
Slim©
  • The Dude Abides...
« Reply #2 on: June 21, 2007, 12:03:18 PM »
You might try Steve Doman as well. He wrote it.
« Reply #3 on: June 21, 2007, 12:13:33 PM »
Yes.  :-)
http://www.theswamp.org/index.php?topic=7272.0
PS Steve's has more user options than mine. Mine strips everything.
« Last Edit: June 21, 2007, 12:15:44 PM by CAB »
Shade
« Reply #4 on: June 21, 2007, 12:17:45 PM »
I have found several linkz for the lisp but they are all dead!
Anyone have a live copy?  :cry:
Slim©
« Reply #5 on: June 21, 2007, 12:25:27 PM »
As it is in the public domain.
Sdoman
« Reply #6 on: June 21, 2007, 04:06:42 PM »
That looks like my old beta 4 version of StripMText, which was never completed due to a variety of reasons.  Better to use v3.09 which can be downloaded at http://cadabyss.wordpress.com/
I have restarted working on the next version of StripMtext BTW.  Any wish lists, comments, or suggestions gladly accepted.
Slim©
« Reply #7 on: June 22, 2007, 12:23:19 AM »
Thanks Steve, it has been very helpful.
And you did say in the header that it was in the public domain. :-)
« Last Edit: June 22, 2007, 12:25:11 AM by Slim© »
Sdoman
« Reply #8 on: June 22, 2007, 09:02:25 AM »
No problemo Slim.  Public Domain is correct.  Thanks for posting!
hudster
« Reply #9 on: June 22, 2007, 10:47:26 AM »
A command line version would be great.
Sdoman
« Reply #10 on: June 22, 2007, 10:56:12 AM »
You got it.  Thanks for the feedback.
Sdoman
« Reply #11 on: June 26, 2007, 08:51:54 AM »
Andy and others,
Regarding a command line option, I was think of introducing a minus command "-stripmtext".   In the current version, the DCL dialog makes choosing format options very easy.  How do you imagine the user entering options at the command line?
I was thinking maybe the user entering a comma delimited string, like the old OSNAP command.  This means the user entering a rather cryptic, hard to remember string.   For font, color, stacking, paragraph, alignment, width, and tracking, the user would enter something like "F,C,S,P,A,W,T".  Of course I'd include an option to pop up the options dialog from the command line.
Just added the following claification:
 "...like the old OSNAP command."
Meaning: -OSNAP command
« Last Edit: June 26, 2007, 03:21:30 PM by 'steved »
« Reply #12 on: June 27, 2007, 11:47:12 AM »
Wouldn't a command line version look like this?
command: -stripmtext
Enter options: "ACFHLOPQStTW~", *=ALL, Enter= Dialog Box:
Or This:
Remove All Formats found [Y/N]:
Remove  Alignment [Y/N]:
Remove  Color [Y/N]:
Remove  Font [Y/N]:
Remove  Height [Y/N]:
Remove  Underscore [Y/N]:
Remove  Overscore [Y/N]:
Remove  Linefeed  [Y/N]:
Remove  Obliquing [Y/N]:
Remove  Spacing (Stacking) [Y/N]:
Remove  Tabs [Y/N]:
Remove  Tracking    [Y/N]:
Remove  Width [Y/N]:
Remove  Non-breaking Space [Y/N]:
Or you could call the subroutine directly from your lisp
(stripmtext Mtext Formats)
Where
(defun stripmtext (Mtext Formats)
  (UnFormat Mtext Formats)
Shade
« Reply #13 on: June 27, 2007, 02:25:00 PM »
Thanks everyone for the help!
Appreciated
Sdoman
« Reply #14 on: June 28, 2007, 09:09:28 AM »
Thanks CAB. I like your first suggestion because it is simple and fast.  The only problem I see with it that a first time user might not understand what to do.  I would need to add "?" for Help.  Your other example would be slower to key in, and the user might be annoyed at having to answer all those prompts.
The current version exposes a function, (stripmtext ss formats), where ss is a selection set of Mtext objects and formats is a concatenated string of format codes.  I added this feature per requests for a version that could be run by script.  It was the quick solution.  The better solution for scripts IMO, is to use the proposed command line version.
I am thinking of removing the exposed stripmtext function, and exposing John's Unformat function, (UnFormat Mtext Formats), which expects a single Mtext string and the format codes.
Actually in the next version, I am working on a totally new parsing engine, so the expose function will be something else.
Appreciated
Shade, From all of use to you "Your welcome!" .
Sorry, I didn't mean to hijack your thread. I should have started a new one regarding new features.
wizman
« Reply #15 on: October 08, 2007, 02:22:31 AM »
hi guys, can i ask, how about if the mtext with embedded formatting from mtext editor is nested in different levels inside blocks?how can i remove the formatting?
« Reply #16 on: October 08, 2007, 09:29:11 AM »
The lisp HERE is an example of how to do it.
Also see nentsel in the VLIDE help file.
« Last Edit: October 08, 2007, 09:30:43 AM by CAB »
wizman
« Reply #17 on: October 09, 2007, 02:10:28 AM »
Thanks for your reply cab, i got too many text like that in a single file, if i use nentsel, it would be one by one.if only there is a way i can loop through each nested mtext.....
« Reply #18 on: October 09, 2007, 09:05:44 AM »
Stripping mText of formatting is a big job. Is there something specific you want to strip out of them?
You can iterate the block collection to find the mText objects you want to strip.
Joe Burke
« Reply #19 on: October 09, 2007, 09:25:48 AM »
Hi Sreve,
For what it's worth, I put John's Unformat function in my toolbox back when you and John collaborated. I'm not sure how many routines call it, but it's more than a few.
I sure miss John...
LE
« Reply #20 on: October 09, 2007, 09:42:34 AM »
I sure miss John...
Joe;
Any idea of what happen to him? (John F. Uhden) - hope that he end up making a lot of money and quit, his job and he is having a lot of fun - his web site still is open :)
btw, I had the chance to talk to him (by phone) some years ago...
Joe Burke
« Reply #21 on: October 09, 2007, 10:10:11 AM »
I sure miss John...
Joe;
Hola Luis,
No, I don't know why he suddenly disappeared. I conversed with him via email back when he was online. But I haven't heard from him since.
You know him. He would not have checked out if he made a lot of money... I suspect what he would have done is spent more time sharing his knowledge.
LE
« Reply #22 on: October 09, 2007, 10:20:24 AM »
Hola Luis,
Well, hope that he is doing just fine! :)
(looking in my phone numbers here, I still have his cell...)
« Reply #23 on: October 09, 2007, 10:46:00 AM »
wizman,
You may try this routine.
Caution, I did very little testing.
;;  CAB  10/09/2007
;;  Strip Mtext within blocks
(defun c:StripBlockMtext (/ adoc text_style_name text_height)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark adoc)
  (vlax-for blk (vla-get-blocks adoc)
    ;; Exclude model and paper spaces and  anonymus blocks
    (if (and  (equal (vla-get-IsLayout blk) :vlax-false)
              (equal (vla-get-IsXref blk) :vlax-false)
              (/= (substr (vla-get-Name blk) 1 1) "*")
(vlax-for ent blk
  (if (= (vla-get-objectname ent) "AcDbMText")
      (setq str (strip_text (vla-get-textstring ent) "*"))
      (vl-catch-all-apply 'vla-put-textstring (list ent str))
  (vla-regen adoc acactiveviewport)
  (vla-endundomark adoc)
;;;=======================[ Strip_Text.lsp ]=============================
;;; Author:  Charles Alan Butler Copyright© 2005-2007
;;; Version: 2.3  Jan. 26, 2006
;;; Version: 3.0  Jun. 19, 2007
;;; Purpose: Strip format characters from text or mtext string
;;; Returns: A string
;;; Sub Routines: -None
;;; Arguments: A string variable to remove formats from & Flag string of formats to remove
;;; Format Flag:
;;;   *    Remove All Formats found
;;;   A    Alignment
;;;   C    Color
;;;   F    Font
;;;   H    Height
;;;   L    Underscore
;;;   O    Overscore
;;;   P    Linefeed (Paragraph)  **** ??
;;;   Q    Obliquing
;;;   S    Spacing (Stacking)
;;;   t    Tabs
;;;   T    Tracking
;;;   W    Width
;;;   ~    Non-breaking Space
;;;   %    Plain Text Formatting
(defun strip_text (str fmt / skipcnt ndx newlst char fmtcode lst_len
                   IS_MTEXT LST  NEXTCHR PT TMP)
(if (or (/= (type fmt) 'Str) (= fmt "*") (= fmt ""))
(setq fmt (vl-string->list "AaCcFfHhLlOoPpQqSsTtQqWw~%"))
(setq fmt (vl-string->list fmt))
  (setq ndx 0
        ;; "fmtcode" is a list of code flags that will end with ;
        fmtcode
         (vl-string->list "CcFfHhTQqWwAa") ;("\C" "\F" "\H" "\T" "\Q" "\W" "\A")
  (if (/= str "") ; skip if empty text ""
      (setq lst      (vl-string->list str)
            lst_len  (length lst)
            newlst   '()
            is_mtext nil ; true if mtext
      (while (< ndx lst_len)
        ;; step through text and find FORMAT CHARACTERS
        (setq char    (nth ndx lst) ; Get next character
              nextchr (nth (1+ ndx) lst)
              skipcnt 0
          ((and (= char 123) (= nextchr 92)) ; "{\" mtext code
           (setq is_mtext t
                 skipcnt 1
          ((and (= char 125) is_mtext) ; "}"
           (setq skipcnt 1)
          ((= char 37) ; code start with "%"
           (if (null nextchr) ; true if % is last char in text
             (setq skipcnt 1)
             ;;  Dtext codes
             (if (= nextchr 37) ; %% code found
               (if (< 47 (nth (+ ndx 2) lst) 58) ; is a number
                 (if (vl-position 37 fmt)
                 ;;  number found so fmtcode %%nnn
                 ;;  convert the nnn to a character
                 (setq skipcnt 5
                       newlst  (append newlst (list (atoi (strcat (chr (nth (+ ndx 2) lst))
        (chr (nth (+ ndx 3) lst))
        (chr (nth (+ ndx 4) lst))
                   ;;  keep the code in the string
                   (setq skipcnt 5
                         newlst  (append newlst (list 37 37 (nth (+ ndx 2) lst)
                                                            (nth (+ ndx 3) lst)
                                                            (nth (+ ndx 4) lst)
                 ;; else letter code, so fmtcode %%p, %%d, %%c
                 ;;  CAB note - this code does not always exist in the string
                 ;;  it is used to create the character but the actual ascii code
                 ;;  is used in the string, not the case for %%c
                 (setq skipcnt 3
                       newlst  (append newlst (list (cond ((= (nth (+ ndx 2) lst) "p") 177)
                                                          ((= (nth (+ ndx 2) lst) "d") 176)
                                                          ((= (nth (+ ndx 2) lst) "c") 216)
                                                          ((= (nth (+ ndx 2) lst) "%")  37)
                 (setq skipcnt 3
               ) ; endif
             ) ; endif
           ) ; endif
          ) ; end cond (= char "%"))
          ((= char 92) ; code start with "\"
           ;;  This section processes mtext codes
             ;; Process Coded information
             ((null nextchr) ; true if \ is last char in text
              (setq skipcnt 1)
             ) ; end cond 1
             ((member nextchr fmtcode) ; this code will end with ";"
              ;; fmtcode -> ("\C" "\F" "\H" "\T" "\Q" "\W" "\A"))
              (while (/= (setq char (nth (+ skipcnt ndx) lst)) 59)
                (setq skipcnt (1+ skipcnt))
             ) ; end cond
             ;; found \U then get 7 character group
             ((= nextchr 85) (setq skipcnt (+ skipcnt 7)))
             ;; found \M then get 8 character group
             ((= nextchr 77) (setq skipcnt (+ skipcnt 8)))
             ;; found \P then replace with CR LF 13 10
             ;;  debug do not add CR LF, just remobe \P
             ((= nextchr 80) ; "\P"
              (if (vl-position 80 fmt)
                (setq newlst  (append newlst '(32))
                      ;ndx     (+ ndx 1)
                      skipcnt 2
             ) ; end cond
             ((= nextchr 123) ; "\{" normal brace
              (setq ndx (+ ndx 1))
             ) ; end cond
             ((= nextchr 125) ; "\}" normal brace
             ) ; end cond
             ((= nextchr 126) ; "\~" non breaking space
              (if (vl-position 126 fmt)
                (setq newlst (append newlst '(32)) ; " "
                      skipcnt 2) ; end cond 9
             ;; 2 character group \L \l \O \o
            ((member nextchr '(76 108 79 111))
              (setq skipcnt 2)
             ) ; end cond
             ;;  Stacked text format as "[ top_txt / bot_txt ]"
             ((= nextchr 83) ; "\S"
              (setq pt  (1+ ndx)
                    tmp '()
              (while
                (not
                  (member
                    (setq tmp (nth (setq pt (1+ pt)) lst))
                    '(94 47 35) ; "^" "/" "#" seperator
                 (setq newlst (append newlst (list tmp)))
              (setq newlst (append newlst '(47))) ; "/"
              (while (/= (setq tmp (nth (setq pt (1+ pt)) lst)) 59) ; ";"
              (setq ndx     pt
             ) ; end cond
           ) ; end cond stmt  Process Coded information
          ) ; end cond  (or (= char "\\")
        ) ; end cond stmt
        ;;  Skip format code characters
        (if (zerop skipcnt) ; add char to string
          (setq newlst (append newlst (list char))
                ndx    (+ ndx 1)
          ;;  else skip some charactersPLOTTABS
          (setq ndx (+ ndx skipcnt))
      ) ; end while Loop
    ) ; end progn
  ) ; endif
  (vl-list->string newlst) ; return the stripped string
) ; end defun
<edit: updated code with Tim's suggestion>
« Last Edit: October 09, 2007, 11:38:01 AM by CAB »
« Reply #24 on: October 09, 2007, 11:18:47 AM »
Alan,
  Your code will try and change xrefs.  To stop that I do it like
(vlax-for blk (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (and
      (eqaul (vla-get-IsLayout blk) :vlax-false)
    .... do your things here ...
« Reply #25 on: October 09, 2007, 11:41:09 AM »
Thanks Tim, I made the changes.
wizman
« Reply #26 on: October 10, 2007, 12:26:22 AM »
that was amazing! thanks cab and tim, you guys are very helpful.keep up!
Gael
« Reply #27 on: November 19, 2007, 04:23:06 PM »
ok, I think I need this .lsp code, however I have been having problems.  I do not have a lot of experience with lsp.....
I found several zip files for this code, however when I save the zip to my computer and try to run lsp in acad I get an error...
It says it can not load the .dcl file.  I have the dcl in the same location as the lsp but I can not move forward....
Anyone have any suggestions?
sinc
« Reply #28 on: November 19, 2007, 04:42:27 PM »
Is the directory containing the DCL in your support path?
Gael
« Reply #29 on: November 19, 2007, 04:45:33 PM »
Thank you very much!!!!!
Spike Wilbury
« Reply #30 on: November 03, 2008, 10:38:53 AM »
I sure miss John...
Joe;
Hola Luis,
Hola Joe,
I just happen to noticed that John Uhden, is back to the adesk lisp ng..... just to let you know :)
http://discussion.autodesk.com/forums/thread.jspa?threadID=699106&tstart=0
(and sorry I know this is an old topic)
Matt__W
  • I like my water diluted.
« Reply #31 on: November 03, 2008, 11:19:18 AM »
Huh... Interesting quote from Jason Piercy towards the bottom... explains quite a bit.
Anne is no longer moderating, hasn't been for a few years now. All of the previous "Facilitators" have also been relieved of their volunteer duties as of early this year. Things are not what they used to be.
Autodesk Expert Elite
TimSpangler
  • CAD Naked!!
« Reply #32 on: November 03, 2008, 12:16:17 PM »
Isn't that the truth.....
ACA 2015 - Windows 7 Pro
