Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Layout Problems
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Layout Problems (Read 2405 times)
Twitch
Guest
Layout Problems
on:
June 19, 2007, 01:32:41 PM »
I've been able to cerate a new layout and set it current and create a custom pages setup.
How can I set my new layout's page setup with code?
If I modify the layout and set the page setup to the one I created by hand everything works great.
Thanks in advance.
Logged
King Gator
C3D user & customizer
Re: Layout Problems
Reply #1 on:
June 19, 2007, 01:49:35 PM »
It would help if you show your code that you are trying to get to work. Since this is a .NET forum, there are a number of different languages you could be using.
Logged
Twitch
Guest
Re: Layout Problems
Reply #2 on:
June 20, 2007, 05:57:23 AM »
Got the answer from Tony T. on the AutoCAD.Net group
Call the CopyFrom method of the Layout, and pass it the PlotSettings object.
PS - No source code needed.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Layout Problems
Reply #3 on:
June 20, 2007, 06:23:24 AM »
Twitch,
Thanks for at least coming back and confirming the status of your question.
However, it's worthwhile keeping in mind Jeff's comments. It DOES help is anyone trying to answer a question has as much usefull information as possible.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
Layout Problems
