Author Topic: Breaking ABS MV-Blocks down to 2D line work?  (Read 3156 times)
Big Boi
« on: June 15, 2007, 10:17:33 AM »
Just curious Is there a command to break ABS MV-Blocks down to 2D line work? I receive backgrounds from the architects that are created in 3D and I needed to know if there is a quick way to convert these for my plan drawings. Thanks.
Guest
Re: Breaking ABS MV-Blocks down to 2D line work?
« Reply #1 on: June 15, 2007, 10:33:50 AM »
If you're using ABS (or MEP)...
From the FILE pull-down...EXPORT TO AUTOCAD --> Select a version of AutoCAD to export to.
Big Boi
« Reply #2 on: June 15, 2007, 10:59:56 AM »
I thought that feature was if you didn't have the latest version of AutoCAD that the file was created in. I just tried that, and yes, that is the best way. Thanks for your help.
