Author Topic: local variable used as function?  (Read 7682 times)
daron
« on: October 30, 2003, 05:23:47 PM »
Here is a piece of code I've got written that works fine,...
;;; variant item ;
(defun vl-variant (method obj)
     (vlax-safearray->list
 (vlax-variant-value
      (method obj)
...but I was checking the file and got this
;warning: local variable used as function: METHOD
I inspected METHOD and got nil, so what's making it local? Here's the calling function.
(vl-variant vla-GetCanonicalMediaNames LayoutObj)
LayoutObj is ActiveLayout property.
I use that as the list in a foreach statement.
SMadsen
« Reply #1 on: October 30, 2003, 06:15:19 PM »
Don't know why it says 'local variable' instead of argument or parameter. Arguments are just local variables that are bound upon entry but it should state the difference. I guess it just has a limited vocabulary?
Anyway. The interpreter have no way of knowing that method will be given as a function. It sees that it is being used as a function and finds it suspicious.
It runs because it works. When you set a breakpoint and trace the stack you will see a call like (#<SUBR @020333e8 vla-GetCanonicalMediaNames> #<VLA-OBJECT IAcadLayout 01af0704>), which is legal.
However, if you were to compile the routine with linking on it would not be able to link to what it sees as a function (added: it is not defined anywhere as a function and therefore can't pass an address to the compiler):
; warning:   cannot LINK METHOD
;               The function is undefined
To get past such problems, you should evaluate it with EVAL:
(eval (list method obj))
daron
« Reply #2 on: October 30, 2003, 06:23:26 PM »
Funny, my biggest concern is when compiling code into fas files. As far as the eval thing goes, are you saying to put (eval (list method obj)) in the arguments cue or where?
SMadsen
« Reply #3 on: October 30, 2003, 06:32:26 PM »
     (vlax-variant-value
And preferrably call the function, or method, quoted in order to be real safe:
(vl-variant 'vla-GetCanonicalMediaNames LayoutObj)
« Reply #4 on: October 30, 2003, 07:41:15 PM »
Quote from: SMadsen
< snip >
Thats the way I do it too Daron/Stig, and haven't had a problem to date.
The extent of error trapping you want to do will depend on your personality .... etc
However .. I would not prefix the function name with vl- , as it is not a VisualLisp built in function, and could get confusing for someone viewing your source.
It sure reads better than this sort of thing scattered dozens of times in your code,
  (setq PrinterList (vlax-safearray->list
                      (vlax-variant-value (vla-getplotdevicenames LayoutObj))
Regards
daron
« Reply #5 on: October 30, 2003, 11:46:56 PM »
So, instead of vl-, maybe I should name them dr- to use my initials and remind me that it's a user defined function? That's a good idea Kerry. Thanks.
