Author Topic: Explode Dims  (Read 7814 times)
Dan
Explode Dims
« on: June 07, 2007, 01:05:09 PM »
Hello All, I am new to the forum, and I have dabbled in VBA, by far I am no expert.
I am trying to figure out a method to explode a dimension.  Any advice would be greatly appreciated.
Thanks,
Dan
Sub ExplodeDim()
Dim sstext As AcadSelectionSet
Dim blk As AcadBlockReference
Dim oEnt As AcadEntity
Dim FilterType(1) As Integer
Dim FilterData(1) As Variant
    On Error Resume Next
    ThisDrawing.SelectionSets.Item("XDim").Delete
    Set sstext = ThisDrawing.SelectionSets.Add("XDim")
    FilterType(0) = 67
    FilterData(0) = 0
    FilterType(1) = 0
    FilterData(1) = "Dimension"
    sstext.Select acSelectionSetAll, , , FilterType, FilterData
    For Each oEnt In sstext
        If TypeOf oEnt Is AcadDimAligned Then
            If oEnt.TextColor = 5 And oEnt.TextOverride <> " " And oEnt.TextOverride <> "" Then
                    'Explode Dim here
            End If
        End If
    Next
End Sub
Guest
Re: Explode Dims
« Reply #1 on: June 07, 2007, 01:20:14 PM »
Thanks,
Dan
From the AutoCAD Bible... 'Thou shalt never explode dimensions!'
Anyways... I don't believe it can be programmatically with VBA.
Speaking of exploding dimensions..... http://www.penwill.com/cadgall07.html
Guest
Re: Explode Dims
« Reply #2 on: June 07, 2007, 01:28:50 PM »
You COULD use this, but it's kind of a hack...
Public Sub Main()
    Dim objDim As AcadDimension
    Dim varPickPoint As Variant
    Dim PickPoint As String
    ThisDrawing.Utility.GetEntity objDim, varPickPoint, "Pick a dimension to explode..."
    PickPoint = varPickPoint(0) & "," & varPickPoint(1) & "," & varPickPoint(2)
    ThisDrawing.SendCommand "EXPLODE " & PickPoint & vbCrLf
End Sub
deegeecees
Re: Explode Dims
« Reply #3 on: June 07, 2007, 01:32:57 PM »
Could use a filter to select all dimension objects, then use the "sendcommand" method. Don't have time to code it, just a thought.
Dan
Re: Explode Dims
« Reply #4 on: June 07, 2007, 03:49:57 PM »
True, but in this case, I wish to explode only a few particular dims.
I did have a lead my research found, but the site is gone:
>Check Randall Rath's site [www.vbdesign.net] and search for it. It is
>possible to explode them programmatically, just not as dimensions.
>Dimensions are, after all, just unnamed blocks. Randall's article will
>explain, but if I remember correctly, a dimension's handle is one number
>less than its blocks name. Anyway, check out his site.
Thanks,
Dan
Maverick®
Re: Explode Dims
« Reply #5 on: June 07, 2007, 04:14:15 PM »
*Sidenote*
  The Squirrels name has been unleashed!  Run! Run for your sanity!
Dan
Re: Explode Dims
« Reply #6 on: June 07, 2007, 04:19:30 PM »
*Sidenote*
Ok, I just started....please clue me in to this!
deegeecees
Re: Explode Dims
« Reply #7 on: June 07, 2007, 04:20:22 PM »
Ahhhhh! Where's my Hollow Point Peanuts?!
Maverick®
Re: Explode Dims
« Reply #8 on: June 07, 2007, 04:31:20 PM »
  Sorry Dan.  Just the reference to RR.  Some of us here have a little bit of history with him.  He used a squirrel for his Avatar.  Totally off topic, I just hadn't seen his name for a while.  :-D
Dan
Re: Explode Dims
« Reply #9 on: June 07, 2007, 04:39:04 PM »
Now this makes sense..Thanks!
Guest
Re: Explode Dims
« Reply #10 on: June 07, 2007, 04:40:19 PM »
Did he ever let you ride his llama??!?
Josh Nieman
Re: Explode Dims
« Reply #11 on: June 07, 2007, 04:42:57 PM »
whoa whoa whoa... that's gettin' kinda...
er...
I think I'll just be on my way now
Guest
Re: Explode Dims
« Reply #12 on: June 07, 2007, 04:45:19 PM »
er...
He even had a nickname for it to.... Ralph the Wonder Llama.   Aaaahhhh yup!
Maverick®
Re: Explode Dims
« Reply #13 on: June 07, 2007, 04:47:40 PM »
It gets worse.
  Ralph is his son.  If they are to be believed.
Dan
Re: Explode Dims
« Reply #14 on: June 07, 2007, 04:51:05 PM »
WOW, what an opening thread. This is my first day here, and I think I opened a door I was completely unaware of.
And all I wanted was to explode a dim, ha ha...
Thanks for the welcome...
