Author Topic: Copy object for use in another program  (Read 1857 times)
Tuoni
  • I do stuff, and things!
« on: June 07, 2007, 08:46:54 AM »
OK... I have looked hard for this but I can't find a way to do it... is it possible or am I flogging a dead horse?
I want to programmatically copy an object (for example a polyline) from modelspace in AutoCAD and insert/paste it into another program without having the background which is brought with it (we use black across the board here).
I have currently got a script which gets the bounding box of each object on the drawing and programmatically does a sendcommand("_COPYCLIP") - far from ideal for two reasons:
1) It takes the background with it
2) It does not copy fast enough to be pasted into the target application - I end up with lots of clones of the same object.
So... is this possible?  I'm not looking for code, just a nudge in the right direction :)
Guest
Re: Copy object for use in another program
« Reply #1 on: June 07, 2007, 10:03:41 AM »
The only thing that I can think of is to WMFOUT selected objects (which won't bring along the black background), then have the program insert the WMF file from the saved location.
Other than that, I got nothing!
DaveW
« Reply #2 on: June 07, 2007, 11:28:01 AM »
Try copybase
