Or try it
It is necessary to choose object, and the command will join all adjoining objects (lines, polylines, arches...) in a polyline
;; pt - Point in WCS !!!
;; - or ENAME or VLA-OBJECT First entities
;; fuzz - fuzz distance
;;posted by VVA http://dwg.ru/forum/viewtopic.php?t=9627&postdays=0&postorder=asc&start=60
;;Return list of vla object
(defun ChainSelectFromAny ( pt fuzz / chain_list couple ept line_list ln loop pda spt ss ln1 cycl)
(cond ((= (type pt) 'ENAME)
(setq ln (vlax-ename->vla-object pt)
pt nil))
((= (type pt) 'VLA-OBJECT)(setq ln pt pt nil))
(t nil))
(if (setq ss (ssget "_I") ss nil
ss (ssget "_X" '((0 . "ARC,LINE,*POLYLINE")))) ;_ end of setq
(if pt (progn
(setq ln1 (vla-addLine
(if (and (zerop (vla-get-activespace (vla-get-activedocument (vlax-get-acad-object))))
(= :vlax-false (vla-get-mspace (vla-get-activedocument (vlax-get-acad-object))))) ;_ end of and
(vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object)))
(vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(vlax-3d-point pt)(vlax-3d-point (mapcar '- pt '(1 1 0)))))
(setq ln ln1)))
(setq spt (vlax-curve-getStartPoint ln) ept (vlax-curve-getEndPoint ln))
(setq line_list (mapcar 'vlax-ename->vla-object
(vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
) ;_ end of mapcar
chain_list nil
chain_list (cons ln chain_list)) ;_ end of setq
(setq line_list (vl-remove-if
'(lambda (x)(eq "AcDb3dPolyline" (vla-get-objectname x)))
line_list)) ;_ end of setq
(setq loop t cycl 0)
(while loop
(while
(setq couple
(vl-remove-if-not
(function (lambda (x)
(or (equal (vlax-curve-getStartPoint x)
fuzz ;<--- äîïóñê
) ;_ end of equal
fuzz ;<--- äîïóñê
) ;_ end of equal
(equal (vlax-curve-getEndPoint x)
fuzz ;<--- äîïóñê
) ;_ end of equal
fuzz ;<--- äîïóñê
) ;_ end of equal
) ;_ end of or
) ;_ end of lambda
) ;_ end of function
line_list
) ;_ end of vl-remove-if-not
) ;_ end of setq
(grtext -1 (strcat "Working. Step - " (itoa (setq cycl (1+ cycl)))))
(if couple (progn
(setq chain_list (append couple chain_list))
(setq line_list (vl-remove ln line_list))
(setq ln (car chain_list))) ;_ end of progn
(setq line_list (cdr line_list))) ;_ end of if
) ;_ end of while
(setq loop nil)
) ;_ end of while
) ;_ end of progn
) ;_ end of if
(setq chain_list (vl-remove ln1 chain_list))
(if (= (type ln1) 'VLA-OBJECT)(vl-catch-all-apply 'vla-erase (list ln1)))
(vl-cmdf "_.redraw") chain_list)
;;;* Mark data base to allow KB:catch.
;;;* http://www.theswamp.org/index.php?topic=15863.0
(defun mip:mark (/ val)
(setq val (getvar "cmdecho"))(setvar "cmdecho" 0)
(if (setq *mip:mark (entlast)) nil
(progn (entmake '((0 . "point") (10 0.0 0.0 0.0)))
(entdel *mip:mark)))
(setvar "cmdecho" val)(princ))
(defun mip:get-last-ss (/ ss tmp val)
(if *mip:mark (progn (setq ss (ssadd))
(while (setq *mip:mark (entnext *mip:mark))(ssadd *mip:mark ss))
(command "._select" ss "")(setq tmp ss ss nil));_progn
(alert "*mip:mark not set. \n run (mip:mark) before mip:get-last-ss."));_if
(setvar "cmdecho" val) tmp)
(defun C:CSS ( / ss pda en fuzz val)
(vl-load-com)(setq val (getvar "cmdecho"))(setvar "cmdecho" 0)
(if (and (setq en (car(entsel "\n Ñhoose first or last line in a chain :")))
(wcmatch (cdr(assoc 0 (entget en))) "ARC,LINE,*POLYLINE")
(setq en (vlax-ename->vla-object en))
(/= "AcDb3dPolyline" (vla-get-objectname en))
(if (null (setq fuzz (getdist "\nFuzz distance < 0 >: ")))(setq fuzz 0))
(setq ss (ssadd))
(foreach item (setq lst (ChainSelectFromAny en (+ fuzz 1e-6)))
(ssadd (vlax-vla-object->ename item) ss))
(mip:mark)
(vl-catch-all-apply '(lambda()
(if (setq pda (getvar "PEDITACCEPT"))(progn
(setq pda (getvar "peditaccept"))
(setvar "peditaccept" 1)
(command "_pedit" "_M" ss "" "_j" "_j" "_b" fuzz "")
(setvar "peditaccept" pda))
(command "_pedit" "_M" ss "" "_Y" "_j" "_j" "_b" fuzz ""))))
(setq lst (vl-remove-if 'vlax-erased-p lst))
(if (setq ss nil ss (mip:get-last-ss))(progn
(if lst (foreach item lst (ssadd (vlax-vla-object->ename item) ss)))
(setq fuzz 0)
(while (setq en (ssname ss fuzz))
(if (/= (cdr(assoc 0 (entget en))) "LWPOLYLINE")
(ssdel en ss)
(setq fuzz (1+ fuzz))))
(sssetfirst ss ss)))
(setq ss nil)
(princ "\nIt is necessary to choose the LINE, ARC or Polyline")
(princ "\nType CSS in command lin")
