Author Topic: Storing notes in a dwg  (Read 12892 times)
nivuahc
« Reply #30 on: July 09, 2004, 08:17:08 AM »
Mine went from about 27,000K to about 28,500K with usage.
Snappy routine!  :)
nivuahc
« Reply #31 on: July 09, 2004, 08:42:30 AM »
Mark, the terminology on the command line is a bit confusing. I'm used to seeing something like
Specify start point of text or [Justify/Style]:
Yours says
Read / Write xNotes [Add View]:
When I first ran it I typed W to write a note... perhaps it would be better presented like this:
Read and write xNotes for this drawing [Add/View]:
Or something like that with the default being Add if the user should press enter.
Just a suggestion.
« Reply #32 on: July 09, 2004, 08:55:40 AM »
good point. I just through that in there for a test, I want to make _one_ dialog box for the whole thing.
« Reply #33 on: July 13, 2004, 07:42:27 AM »
new version. one dialog box. start with 'myxnotes'
http://www.theswamp.org/swamp.files/mark/MyxNotes.lsp
the code is still messy!
MSTG007
« Reply #34 on: July 13, 2004, 08:01:50 AM »
NOT TO SHABBY
Civil3D 2020
« Reply #35 on: July 13, 2004, 09:26:10 AM »
Neat-o Mark,
Just tried it out.
One thing, when you type a long note the note scrolls in the entry window
but when you retrieve the notes the note in the view window doesn't wrap.
Did you have plans to high lite the existing note and have it appear in the
entry window so you can edit & or view the entire note?
nivuahc
« Reply #36 on: July 13, 2004, 09:44:06 AM »
Ditto what CAB just said ^^
« Reply #37 on: July 13, 2004, 10:40:18 AM »
Quote from: CAB
Neat-o Mark,
Just tried it out.
haven't got that far yet! good idea though. right now if you just select an existing note and click OK it will print to the command line.
« Reply #38 on: July 13, 2004, 11:14:47 AM »
Something like this? I'm sure you can do better.
It messed up your return string at the command line though.
 (defun build-xnotes-lst (lst / notes_lst notes)
    (foreach item lst
      (setq notes (cdr (assoc 301 item)))
      (setq notes_lst
             (append
               (list
                 (strcat
                   (cdr (assoc 2 item))
                   (cdr (assoc 300 item))
                   (substr notes 1 40)
               notes_lst
      ); set
      (if (> (strlen notes) 40)
          (setq idx 41)
          (while (< idx (strlen notes))
            (setq notes_lst
             (append
               (list
                 (strcat
                   (substr notes idx 40)
               notes_lst
           ); set
           (setq idx (+ idx 40))
          ); while
      ); endif
    ); foreach
    (reverse notes_lst)
PS i know you are buisy, so don't mess with this now, if you are Swamped. 8)
Couldn't resist.
