Hey CAB,
My company finally purchased a License of Hurricane Batch script generator which is what I was trying to use to modified Plottabs routine on. I am trying again to get it to work and encountering the same problems. I have simplified it to only include one plot configuration trying to get it to work on multiple drawings first which seems to be the problem. I tested it on two plotters and it worked on the first drawing but did not plot anything from the second. We were thinking it was halting because of a qsave. I have taken the close off the end and set the program to test run which I found out eliminates the qsave at the end but still no go. Can you please help me reanalyze this because I am stumped at this point.
Old ThreadHere is my generated script:
_OPEN
"c:\Documents and Settings\danielk\Desktop\batch test\batch test 1.dwg"
(if (or sub_plottabs (/= (load "plottabs.lsp" "fail") "fail"))
(foreach ps '(("small_copy" nil 1))
(setq *ptdebug* t)
(sub_plottabs (list (car ps) (nth 2 ps) "Tab" (cadr ps) nil t t "~" nil nil t T "" "*"))
(princ "\nCould not load PlotTabs.lsp or plotHelper.lsp")
_OPEN
"c:\Documents and Settings\danielk\Desktop\batch test\batch test 2.dwg"
(setq *ptdebug* t)
