cab at first i was trying to run a few lisp routines we have for importing all of the pagesetups from our template after the drawing is opened but that wasn't working so I decided to just load the small copy one into the drawings for testing. i tried running the script with sdi set to 1 several times and it never proceeded to the second drawing. see below: I also tried it with sdi set to 0 and took out the closes and saves with the same results? :ugly: take a look and see if you see any reason why it didn't work as expected.
Command: '_script
Command: SDI
Enter new value for SDI <0>: 1
Command: OPEN
Really want to discard all changes to drawing? <N> Y
Enter name of drawing to open <D:\Drawings\batch test\batch test 1.dwg>:
"D:\Drawings\batch test\batch test 1.dwg"
Opening an AutoCAD 2004/LT 2004 format file.
Regenerating layout.
Command:
Command:
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
<<ACAD.dvb Loaded>>
<<AngleConnector.dvb Loaded>>
<<CommonDialog.dvb Loaded>>
<<Gatte.dvb Loaded>>
<<UpdateAttribute.dvb Loaded>>
<<vm_reflected.dvb Loaded>>
<<CPS.dvb Loaded>>
AutoCAD menu utilities loaded.
Command: (if (or sub_plottabs (/= (load "plottabs.lsp" "fail") "fail"))
(_> (foreach ps '(("small_copy" nil 1) ("d-prot Xerox510" nil 1))
((_> (setq *ptdebug* t)
((_> (sub_plottabs (list (car ps) (nth 2 ps) "Tab" (cadr ps) nil t t "~"
nil nil t T "" "*"))
((_> )
(_> (princ "\nCould not load PlotTabs.lsp or plotHelper.lsp")
(_> )
Plot Tabs is loaded, Enter PLotTabs to run.
PlotTabs01.14.07 running.
* * * * S t a r t i n g t h e P l o t * * * *
* * * * Debug Mode is ON * * * *
=-=-=-=-=-=-=-=-=-= DEBUG MODE =-=-=-=-=-=-=-=-=-=-=
* * * * Variable Dump * * * *
-> small_copy [Plot-Config]- Name if plot, default to Current
-> 1 [Plot-QTY]- number of copies of each sheet
-> Tab [Plot-order]- Sort order of tabs "Alpha" "Numeric" "Tab" order
-> False [RevOrder]- t/nil Reverse the order of plots
-> True [PlotAllTabs]- t/nil Plot All tabs or use picks
-> True [setlaystate]- t/nil set layer state per tab name
-> False [PlotToFile]- Flag
-> [MyPath]- Path for 'Plot To File'
-> 1[Quantity]- number of sets
-> True [SaveLayout]- Always True- Not an option in this version
-> True [CollateSets]- t/nil Collate plan sets when more than one plotted
-> True [ExcludeTab]- t/nil Flag to exclude tabs with flag character
-> ~ [ExcludeChr]- "~" Character marker for exclude tabs
-> False [zoom-all]- t/nil Zoom layout before plotting
-> 0 [config#]- pointer to config name in list, 0= first item
-> Config List [config-list]->
Current
A1-FX
A1-PDF
A1-PROT
D-prot Xerox510
HP LASER 11x17
LANDSCAPE
LANDSCAPE-PDF
LEGAL
LEGAL-FAX
LEGAL-PDF
d-prot-500ps
d-prot-800
small_copy
-> Tab Name to Plot [tab-list]->
D-PROT
D-PROT (5)
-> / [Tabs2Plot]-
* * * * End Variable Dump * * * *
Plotting layout "D-PROT"...
._-layer
Current layer: "0"
Enter an option
[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/MATerial/Plot/Freeze/Thaw/LOck/Unlock
/stAte]: _state
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: _restore
Enter name of layer state to restore or [?]: D-PROT
Unknown layer state name.
Enter an option [?/Save/Restore/Edit/Name/Delete/Import/EXport]: Enter an
option
/stAte]:
Command:
* * * * Page Set Up Info * * * *
-> Config Name : LASER PRINTER.pc3
-> Style Sheet : small_copy.ctb
-> CanMed Name : Letter
-> Center Plot : :vlax-true
-> Paper Units : 0
-> Plot Hidden : :vlax-false
-> Plot Rotate : 1
-> Plot Type : 1
-> Plot Origin : (13.208 0.0)
-> Plot W-Styles: :vlax-true
-> Scale Lin Wts: :vlax-false
-> Std Scale : :vlax-true
-> window state : 3
-> path : C:\Program Files\AutoCAD 2008
* * * * End Page Set Up Info * * * *
Effective plotting area: 7.00 wide by 10.50 high
Plotting viewport 1.
Plotting layout "D-PROT (5)"...
._-layer
Current layer: "0"
Enter an option
/stAte]: _state
Enter name of layer state to restore or [?]: D-PROT (5)
option
/stAte]:
Command:
-> Paper Units : 0
-> Plot Rotate : 1
-> Plot Type : 1
-> window state : 3
**** Plot Sets Complete ****
1 copy of 2 layouts = 2 sheets plotted.
-> d-prot Xerox510 [Plot-Config]- Name if plot, default to Current
Current
A1-FX
A1-PDF
A1-PROT
D-prot Xerox510
HP LASER 11x17
LANDSCAPE
LANDSCAPE-PDF
LEGAL
LEGAL-FAX
LEGAL-PDF
d-prot-500ps
d-prot-800
small_copy
D-PROT
D-PROT (5)
-> / [Tabs2Plot]-
._-layer
Current layer: "0"
Enter an option
/stAte]: _state
option
/stAte]:
Command:
-> Config Name : Xerox 510.pc3
-> Style Sheet : Xerox_510.ctb
-> CanMed Name : User267
-> Center Plot : :vlax-false
-> Paper Units : 0
-> Plot Rotate : 0
-> Plot Type : 1
-> Plot Origin : (16.51 7.40613)
-> window state : 3
Effective plotting area: 34.50 wide by 23.00 high
._-layer
Current layer: "0"
Enter an option
/stAte]: _state
option
/stAte]:
Command:
-> Paper Units : 0
-> Plot Rotate : 0
-> Plot Type : 1
-> window state : 3
